Hey Gurus!
I am trying to discover why a CNC Lathe (Nardini) with a Series 20T Fanuc control will not execute a G01 code.
You can program a G00 and the lathe will respond perfectly and you have full control over Rapid Feedrate via the operator knob on the Crossfeed control box.
However, If you try to execute a G01, the lathe does not move at all.
There are no errors, and the 'DIAG' screen shows "In Motion = 1"
The 'Start' button is also flashing green.....
Hmmmm....It is almost like the lathe THINKS it is moving, but.....nope.
Example :
G00 W 3.0;
(Results in perfect operation.....)
G01 W3.0 F1.0;
(Results in no movement........no errors.....)
This machine was functioning perfectly with existing programs...and recently stopped.
I was wondering if it is possible to program some type of code that would block a G01 from operation.....
Be great to hear some suggestions!
Thanks!
