586,089 active members*
3,876 visitors online*
IndustryArena Forum: Leadshine
Page 1 of 8 123
Threads 1 to 20 of 148
Discuss Leadshine stepper/servo drives, motors, and controls here!
  1. Not Understanding Leadshine Driver AC and DC Input
    Started by NIC 77, 06-18-2017 05:49 PM
    cnc, input, leadshine, power, understanding
    03-09-2024, 09:45 AM Go to last post
    02-25-2024, 02:52 PM Go to last post
    01-09-2024, 03:50 AM Go to last post
  2. the HBS86H ENA+ input issue
    Started by adamscnc, 05-09-2023 10:13 PM
    05-09-2023, 10:13 PM Go to last post
  3. Question Leadshine vs other Chinese brands
    Started by Redi, 03-28-2023 06:44 PM
    chinese, direct, finding, leadshine, servo
    03-29-2023, 07:17 PM Go to last post
  4. Talking What resistor to use ?
    Started by Kristjan1505, 02-08-2023 11:28 AM
    24v, alarm, plc, position, switch
    02-08-2023, 11:28 AM Go to last post
    06-28-2022, 07:36 PM Go to last post
  5. MX4660 Speed Control for 2.2 KW huanyang vfd
    Started by Dekman, 01-29-2016 05:13 AM
    2 Pages
    1 2
    06-27-2022, 10:10 PM Go to last post
  6. ACS806 and ACM604V60-01-1000 tuning
    Started by Mud_, 05-17-2022 06:50 PM
    05-17-2022, 07:23 PM Go to last post
  7. Red LED alert
    Started by Georgie, 03-30-2022 08:51 PM
    axis, capable, carrying, controller, red
    03-30-2022, 08:51 PM Go to last post
  8. Leadshine technical support available on CNCzone.com
    Started by Leadshine, 05-28-2015 09:44 AM
    3 Pages
    1 2 3
    12-02-2021, 04:36 AM Go to last post
  9. MX4660 Estop wiring
    Started by TMToronto, 06-23-2021 01:44 PM
    button, estop, masso, mx4660, pins
    10-05-2021, 03:54 PM Go to last post
  10. MX4660 shunt regulator option
    Started by TMToronto, 07-01-2021 04:11 PM
    10-05-2021, 03:24 PM Go to last post
  11. Problem with MX4660 Fault output on DB25 PIN #15
    Started by TMToronto, 10-03-2021 01:27 AM
    cnc, fault, forum, output, pin
    10-05-2021, 08:54 AM Go to last post
    07-06-2021, 11:59 AM Go to last post
  12. chain leadshine fault outputs?
    Started by Janosch89, 05-20-2021 01:31 PM
    06-15-2021, 12:57 AM Go to last post
  13. mx4660 doesn't communicate with ESS and mach3
    Started by Bigtoe, 06-03-2021 07:43 PM
    cnc, lights, mach3, motor, mx4660
    06-03-2021, 07:43 PM Go to last post
    06-02-2021, 02:53 PM Go to last post
  14. noise?
    Started by Janosch89, 04-20-2021 09:30 PM
    05-17-2021, 02:02 PM Go to last post
  15. Alarm wiring on Rnr motion card (Red)
    Started by trivalb, 05-09-2021 03:58 PM
    24v, alarm, alarm+, driver, gnd
    05-10-2021, 11:13 AM Go to last post
Page 1 of 8 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
