586,082 active members*
3,604 visitors online*
IndustryArena Forum: HEIDENHAIN -> iTNC530 PC-SOFTWARE
Page 1 of 5 123
Threads 1 to 20 of 81
TALK about the PC-SW iTNC530
  1. Tncremo 640
    Started by stuflo, 04-11-2024 10:04 PM
    changing, connect, laptop, machine, won’t
    04-12-2024, 01:48 AM Go to last post
    03-08-2024, 01:20 PM Go to last post
  2. buffer batteries
    Started by bigmark, 10-18-2023 10:12 AM
    batteries, buffer, changed, older, vmcs
    10-19-2023, 11:33 AM Go to last post
  3. Exclamation HELP! Problem with C axis referencing on ITNC530
    Started by ugs, 04-08-2021 09:01 AM
    axis, cnc, forum, itnc 530, software
    09-05-2023, 05:11 PM Go to last post
    06-07-2023, 04:35 PM Go to last post
  4. 90 deg head programming
    Started by Jjcnc1, 01-31-2023 04:04 PM
    change, code, head, perform, waist
    02-01-2023, 04:11 AM Go to last post
  5. Get data from iTNC530
    Started by hiwilson, 07-04-2019 02:05 PM
    07-30-2022, 01:16 AM Go to last post
  6. iTNC 530 Lathe
    Started by barbelas, 03-26-2022 12:59 PM
    bad, compensate, english, lathe, tool
    03-26-2022, 12:59 PM Go to last post
  7. wrong program itnc 530
    Started by reza703, 07-12-2021 06:40 PM
    5 axis, bridgeport, powermill, solidcam, tooltip goes wrong
    07-13-2021, 07:47 AM Go to last post
  8. CNC dont Move on F code
    Started by reza703, 06-27-2021 09:40 PM
    bridgeport, feedhold, itnce 530, mp parameter, mv204
    07-12-2021, 06:26 PM Go to last post
    07-06-2021, 11:42 PM Go to last post
  9. Axis Movement
    Started by bosnar, 06-24-2021 04:02 AM
    axis, plane, rotation, software, straight
    06-24-2021, 04:02 AM Go to last post
  10. Guard door - Probe Heidenhain
    Started by skucku99, 10-17-2020 08:39 PM
    - probe, door, guard, heidenhin, probe
    10-24-2020, 08:36 PM Go to last post
  11. Post iTNC530 backup
    Started by BrendanDixon, 09-05-2017 06:38 AM
    05-12-2020, 07:10 PM Go to last post
  12. Problem with new iTNC530
    Started by arenamember, 03-24-2013 05:55 PM
    03-24-2013, 05:55 PM Go to last post
  13. Plane function not possible iTNC530
    Started by arenamember, 03-17-2013 05:16 PM
    03-17-2013, 05:16 PM Go to last post
  14. Chamfer with iTC530 system
    Started by arenamember, 02-23-2013 07:24 PM
    02-23-2013, 07:24 PM Go to last post
    02-12-2013, 04:24 AM Go to last post
  15. Open files made by iTNC530
    Started by arenamember, 02-10-2013 01:25 PM
    02-10-2013, 08:01 PM Go to last post
    12-29-2012, 02:10 PM Go to last post
Page 1 of 5 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
