586,082 active members*
3,703 visitors online*
IndustryArena Forum: K2CNC
Page 1 of 8 123
Threads 1 to 20 of 155
Discuss K2cnc machines here!
    01-12-2024, 12:40 PM Go to last post
    01-04-2023, 04:09 PM Go to last post
  1. K2 Y axis and X axis Configurations ( backlash )
    Started by hkinkade, 10-05-2022 08:50 PM
    axis, drives, i’m, pinion, rack
    10-13-2022, 06:04 PM Go to last post
  2. K2CNC servo motor
    Started by elflaco1964, 08-10-2022 01:22 AM
    k2cnc, number, part, replacement, servo
    09-06-2022, 08:25 PM Go to last post
  3. K2 CNC (maybe KG-3925) not working...
    Started by rjsgh0406, 03-05-2020 11:08 PM
    04-09-2021, 02:51 PM Go to last post
    11-11-2020, 02:36 PM Go to last post
  4. did k2 go out of buisiness ?
    Started by Lethrahn, 02-14-2015 01:36 AM
    2 Pages
    1 2
    09-30-2020, 06:00 AM Go to last post
  5. Angry K2 Router Problems!!!!!
    Started by spence21, 09-15-2020 07:43 PM
    configuration, guessing, movement, problem, router
    09-15-2020, 07:43 PM Go to last post
  6. Angry K2 CNC Router Issues
    Started by spence21, 09-09-2020 04:43 PM
    cnc, info, router, start, wiring
    09-09-2020, 04:43 PM Go to last post
  7. K2 CNC distance problems
    Started by bootleg, 04-24-2016 02:00 PM
    cnc, computer, k2 cnc, ruler, software
    04-09-2020, 09:40 PM Go to last post
  8. Random limit switch false trip
    Started by lumenire, 04-02-2020 02:27 AM
    2 Pages
    1 2
    04-04-2020, 03:25 AM Go to last post
  9. K2 Servo Controller Connections
    Started by lumenire, 11-09-2019 04:27 PM
    11-09-2019, 04:27 PM Go to last post
    10-08-2019, 08:58 AM Go to last post
  10. K2CNC Servo Motor twitching when idle
    Started by lumenire, 09-23-2019 05:02 PM
    idle, k2cnc, plaster, servo motor twitching, twitch
    09-23-2019, 05:02 PM Go to last post
  11. K2CNC bearing block repair/replace
    Started by ndplume59, 01-12-2019 03:59 PM
    01-12-2019, 03:59 PM Go to last post
  12. Troubleshooting
    Started by BFHammer, 11-19-2018 08:33 PM
    k2cnc, mach 3, motion, power, replaced
    11-26-2018, 06:42 PM Go to last post
  13. K2CNC/MACH3 stops in middle of job
    Started by lumenire, 12-19-2017 05:10 PM
    2 Pages
    1 2
    11-11-2018, 03:23 PM Go to last post
    10-26-2018, 08:11 PM Go to last post
  14. Question K2 2525LT Y axis tram adjustment
    Started by Kris-K2, 09-21-2017 08:11 PM
    01-27-2018, 09:04 PM Go to last post
  15. K2 CNC manual
    Started by lumenire, 12-18-2017 02:31 AM
    4x2, cnc, manual
    01-27-2018, 08:55 PM Go to last post
Page 1 of 8 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
