586,089 active members*
3,958 visitors online*
IndustryArena Forum: Xylotex
Page 1 of 15 12311
Threads 1 to 20 of 290
Discuss all Xylotex drivers here!
  1. Re: Xylotex 3 axis controller with 269oz motors
    Started by juandkeim, 04-15-2024 11:46 PM
    axis, controller, find, services, xylotex
    04-15-2024, 11:46 PM Go to last post
  2. captzman193
    Started by captzman193, 10-30-2020 11:28 PM
    cnc, lights, low, switches, top
    11-13-2022, 12:55 PM Go to last post
  3. Xylotex controller
    Started by cnc Rookie, 06-21-2017 05:01 PM
    axis, mach, running, stepper, xylotex
    11-05-2022, 07:46 PM Go to last post
  4. Stepper Motors
    Started by ironclad246, 03-11-2019 02:49 AM
    inches, mach3, motors, steps, tuning
    10-11-2022, 09:04 PM Go to last post
  5. Stepper Motors
    Started by ironclad246, 03-11-2019 01:22 AM
    10-03-2022, 02:46 AM Go to last post
    09-22-2022, 03:24 AM Go to last post
  6. Xylotex Board quit working !
    Started by kel1, 03-28-2009 07:02 PM
    away, down, took
    11-10-2016, 06:30 AM Go to last post
    10-16-2016, 12:00 AM Go to last post
    03-03-2016, 07:58 PM Go to last post
  7. Xylotex board used in old CNC Shark controller.
    Started by dreiii, 04-25-2015 09:47 PM
    board, cnc, laser, turn, unit
    04-26-2015, 02:52 AM Go to last post
  8. Xylotex 4 axis control box for sale.
    Started by hacker7, 09-29-2014 04:44 AM
    170, 4 axis, 4x4, axis, box, cnc, cnc control, con, control, control box, ebay, for sale, issue, link, router, router table, sale, table, time, wrong, xylotex
    10-01-2014, 05:48 AM Go to last post
  9. Adding estop to Xylotex board
    Started by cgallery, 09-22-2014 03:46 AM
    cnc, cnc router, controller, delay, drive, e-stop, emergency stop, mach, mach3, manual, motion, parallel, parallel port, point, reset, router, screw, stepper, thinking, time, wired, xylotex
    09-29-2014, 12:54 AM Go to last post
  10. Setting VRef on original Xylotex 3-axis board
    Started by cgallery, 09-20-2014 04:42 AM
    09-21-2014, 02:55 AM Go to last post
  11. Xylotex 425 motors with gecko G540?
    Started by StuartC, 05-20-2014 12:35 PM
    08-20-2014, 03:58 PM Go to last post
  12. Motor moves faster and farther in one direction
    Started by momojoey, 07-15-2014 12:35 AM
    board, direction, jogging, mach, mach 3, mach2, make, mechanical, motor, motor shaft, motors, move, one, position, problem, return, shaft, software, star, working, xylotex
    07-15-2014, 12:35 AM Go to last post
  13. New box and limit switches
    Started by clembrant, 03-31-2014 11:18 PM
    add, board, box, break out board, i/o, kit, limit, limit switches, swi
    04-11-2014, 12:11 PM Go to last post
  14. electronics help please
    Started by brent48, 03-25-2014 09:03 AM
    3 axis, axis, board, breakout, breakout board, burn, burnt, cable, cnc, configure, direction, electro, electronics, help please, jog, mach, mach3, motors, move, power, printer, problem, test, xylotex, z axis
    03-25-2014, 09:59 AM Go to last post
  15. replacement power supply
    Started by bartniswonger, 10-16-2013 12:39 PM
    10-18-2013, 02:23 PM Go to last post
  16. Single Axis Problem
    Started by Taflin, 09-11-2013 08:25 PM
    09-11-2013, 08:25 PM Go to last post
    07-28-2013, 04:42 AM Go to last post
Page 1 of 15 12311
Forum Information and Options
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
