586,082 active members*
3,563 visitors online*
IndustryArena Forum: Charter Oak Automation Support Forum
Page 1 of 34 12311
Threads 1 to 20 of 670
Discuss Industrial Hobbies/Charter Oak Automation Milling machines and get direct support here.
  1. Charter Oak mill x-axis backlash help
    Started by mattinaustin, 03-27-2023 07:15 PM
    03-29-2023, 09:30 PM Go to last post
  2. Main Motor for IH Mill ZAY7045FG ?
    Started by richlandrick, 02-06-2022 07:07 PM
    main, mill, motor, plate, unreadable
    02-08-2022, 10:11 PM Go to last post
  3. IH Controller schmaticm + specs
    Started by qbit, 04-15-2021 02:36 AM
    charter, cnc, control electronics, industrial hobbies mill, specs
    05-14-2021, 02:46 PM Go to last post
  4. ball screw nut replacement
    Started by bit pusher, 04-13-2021 04:11 AM
    ball, nut, replacement, screw, tommy
    04-23-2021, 03:48 PM Go to last post
    04-17-2021, 04:32 AM Go to last post
  5. IH ENCODERS
    Started by bohica, 12-31-2020 01:03 AM
    apparently, bit, cnc, dust, encoder
    12-31-2020, 01:03 AM Go to last post
  6. IH SERVO MOTOR
    Started by bohica, 12-10-2020 06:21 PM
    jim, motor, replacement, sell, servo
    12-10-2020, 08:54 PM Go to last post
  7. Sometimes the Z axis Drops after power-down
    Started by pryotex, 03-25-2017 09:28 AM
    drops, occurred, power, time, tool
    01-22-2020, 10:30 PM Go to last post
  8. Large seal in head under the motor, 35x62x...?
    Started by QSIMDO, 12-26-2019 10:45 PM
    35x62x12, head, motor, removed, seal
    12-26-2019, 10:45 PM Go to last post
  9. Head bolt dimensions head spacer
    Started by williamsmotower, 12-05-2019 05:53 PM
    bolt, column, dimensions, head, special
    12-05-2019, 05:53 PM Go to last post
  10. Glad I didnt Buy One !
    Started by madman, 09-15-2014 03:50 PM
    10-03-2019, 02:51 AM Go to last post
  11. How to Change Bearings - COA Square Col
    Started by Danal, 09-20-2019 10:58 PM
    bearings, load, running, spindle, square
    09-22-2019, 11:08 PM Go to last post
    08-11-2019, 10:25 AM Go to last post
  12. Charter Oak not responding?
    Started by QSIMDO, 08-01-2019 04:22 PM
    anymore, full, mail, mailbox, voice
    08-02-2019, 08:56 PM Go to last post
    07-10-2019, 04:05 AM Go to last post
  13. BT/NT30 Spindle for 12Z Mill?
    Started by tulsah, 01-18-2019 04:04 AM
    12z, assuming, bt/nt30, cnc, spindle
    05-16-2019, 02:27 PM Go to last post
    05-15-2019, 07:55 AM Go to last post
  14. Model C8250
    Started by crazybrit, 04-23-2019 02:04 AM
    04-24-2019, 01:18 AM Go to last post
  15. Spindle Problem?
    Started by bohica, 03-07-2019 08:46 PM
    cnc, problem, rpm, running, spindle
    04-07-2019, 05:44 PM Go to last post
    03-10-2019, 01:02 PM Go to last post
Page 1 of 34 12311
Forum Information and Options
Users Browsing this Forum
There are currently 2 users browsing this forum. (0 members & 2 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
