586,077 active members*
3,777 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions
IndustryArena Forum: Material Machining Solutions
Page 1 of 36 12311
Threads 1 to 20 of 712
Discuss general material machining problems and solutions here.
  1. punching rubber
    Started by subnetgate, 11-29-2023 09:10 PM
    11-29-2023, 09:10 PM Go to last post
  2. Struggling to break chips while turning 4130.
    Started by rbeachner, 10-06-2023 07:59 AM
    10-18-2023, 08:55 AM Go to last post
  3. Tip of endmills keep chipping
    Started by Hyudryu, 07-01-2023 10:59 PM
    6mm, cnc, end, flute, holes
    09-11-2023, 11:48 PM Go to last post
  4. some questions about 6al-4v
    Started by QuinnSjoblom, 05-06-2023 09:39 PM
    direction, find, grain, parts, titanium
    05-08-2023, 09:45 PM Go to last post
  5. machine handling
    Started by mikey B, 06-06-2022 03:07 PM
    06-06-2022, 06:18 PM Go to last post
  6. Price for Alloy Recycling
    Started by boydage, 02-24-2022 05:42 AM
    alloy, surprised, fact, $1.40kg, sm-n970f
    04-30-2022, 06:57 PM Go to last post
    03-17-2022, 04:27 AM Go to last post
  7. Choosing material for a shift fork
    Started by Paraquat, 03-02-2022 06:13 PM
    aluminum, fork, machinist, shift, silicon
    03-16-2022, 03:30 PM Go to last post
    03-01-2022, 04:34 PM Go to last post
  8. Nickel Boron Coating for Firearm
    Started by K9guy, 07-13-2021 11:52 PM
    07-13-2021, 11:52 PM Go to last post
  9. Feeds and Speeds 6061
    Started by mofosheee, 05-06-2019 01:08 PM
    depth, feeds, flute, forum, speeds
    06-13-2021, 05:33 PM Go to last post
    03-22-2021, 08:40 PM Go to last post
  10. PaperStone
    Started by cpnagle_cnc, 01-26-2021 09:54 PM
    03-12-2021, 04:19 PM Go to last post
    01-15-2021, 10:45 PM Go to last post
  11. DURALCAN
    Started by MichalTA, 10-27-2020 11:33 AM
    10-27-2020, 11:33 AM Go to last post
  12. Coating for insert holders
    Started by flick, 04-23-2018 02:36 AM
    coating, corrosion, holders, insert, invincible
    10-13-2020, 12:37 PM Go to last post
  13. Need help with material choice
    Started by Hydrops, 05-30-2020 12:49 PM
    09-08-2020, 07:34 AM Go to last post
  14. Aerospace CNC Machining parts problem
    Started by EBI-PARTS, 09-05-2019 08:22 AM
    aerospace, cnc, machining, manufacturing
    09-08-2020, 03:31 AM Go to last post
  15. S/F - Small holes in mild steel.
    Started by Wtz-44, 06-25-2020 07:53 AM
    06-25-2020, 04:30 PM Go to last post
  16. Talking Has anyone used FIBEROCK
    Started by rfjr88, 06-11-2020 08:04 PM
    bits, feed, fiberock, material, order
    06-11-2020, 08:04 PM Go to last post
Page 1 of 36 12311
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
