586,075 active members*
3,810 visitors online*
IndustryArena Forum: WinCnc
Page 1 of 5 123
Threads 1 to 20 of 93
Discuss WinCnc Here!
  1. WINCNC Z axis only travels down HELP?
    Started by casec11, 04-20-2024 10:34 PM
    cnc, software, travels, wincnc, z-axis
    04-20-2024, 10:34 PM Go to last post
  2. WinCNC Tool Setup
    Started by TECNC, 03-19-2024 09:54 PM
    atc, cnc, machine, tool, wincnc
    03-20-2024, 10:18 PM Go to last post
    03-06-2023, 03:31 PM Go to last post
  3. winCNC screwmapping?
    Started by KT88saturate, 12-30-2022 03:12 AM
    checks, error, machine, screwmapping, wincnc
    12-30-2022, 03:12 AM Go to last post
  4. need to program a button
    Started by RonRowland77, 10-24-2022 09:22 AM
    button, hieght, program, tool, wincnc
    10-24-2022, 09:22 AM Go to last post
    10-24-2022, 09:02 AM Go to last post
  5. Old Mastercam Post for wincnc?
    Started by AMG Guitars, 12-12-2020 06:54 AM
    file, mastercam, post, pst, wincnc
    03-18-2022, 01:40 AM Go to last post
  6. Program stops mid file
    Started by woodenfred, 11-24-2020 10:38 PM
    problem, router, run, running, stops
    11-24-2020, 10:38 PM Go to last post
  7. Need some help
    Started by OliverMoore, 08-12-2020 10:55 PM
    10-23-2020, 02:59 PM Go to last post
  8. Cutting on the inside or outside of a line
    Started by buildhauer, 06-03-2020 05:52 PM
    cnc, forum, inside, software, version
    06-08-2020, 07:36 PM Go to last post
  9. INI file definitions and Rapids
    Started by SteveS, 05-04-2020 10:52 PM
    cam, forum, rapids, wincnc, wincnc.ini
    05-05-2020, 06:58 PM Go to last post
    03-28-2020, 01:43 PM Go to last post
  10. Spare WinCNC PCI card available
    Started by spepin, 03-05-2020 06:37 PM
    card, pci, pci7200, wincnc
    03-05-2020, 06:37 PM Go to last post
  11. Version 2.6.15 is not Reading G83
    Started by steina81, 03-01-2020 03:41 AM
    g83, software, updated, version, win
    03-01-2020, 03:41 AM Go to last post
  12. m37 command
    Started by Doug Smith, 11-25-2019 05:50 PM
    cnc, height, move, spaces, tools
    11-26-2019, 02:00 AM Go to last post
    10-24-2019, 07:59 AM Go to last post
  13. Configuring Z Axis Touch Plate
    Started by elcanadian, 11-19-2018 09:58 PM
    touch plate, wincnc, zero z axis
    01-23-2019, 01:48 AM Go to last post
  14. Rotary Axis is using inches for degrees!
    Started by scweaver59, 11-13-2018 02:37 AM
    11-15-2018, 12:10 PM Go to last post
  15. Rotary axis speed control
    Started by scweaver59, 10-31-2018 08:40 PM
    b-axis, raster, rotary, software, y-axis
    10-31-2018, 08:40 PM Go to last post
    10-31-2018, 07:22 PM Go to last post
Page 1 of 5 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
