587,421 active members*
3,106 visitors online*
Results 1 to 2 of 2
    Jan 2007
    93
    Arrow GE FANUC SERIES 15M
    FRIENDS,
    TRYING TO SWITCH ON A OLD M/C WITH FANUC 15M MODEL MAKINO MC-86.
    AS SWITCH ON THE M/C FOLLOWING STEPS SHOWED ON SCREEN,
    RAM TEST : PASS
    ROM TEST : PASS
    SLOT (0222) END
    SLOT 02 (011D) : --------------blank
    AND SYSTEM DOES NOT BOOT FURTER.
    ANY SUGGESTION PLEASE.
    THANKS.
    [email protected]
    Oct 2007
    179
    Rajesh,
    Might be worth checking the internet for some pics of your motherboard to check if all the boards are in place first...
    Can you get to a parameter screen..?
    If you have lost the parameters then this may cause your system not to boot..
    I think the 15M has a battery backed sram board for storing parameters and diagnostics but i'm not very familiar with 15M.
    This sight is very good for info on most controls.
    www.memex.ca
    John.
  1. Need Help With a Fanuc Series 5
    By RGeo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-30-2007, 03:11 AM
  2. Fanuc Series 18T
    By jorgehrr in forum G-Code Programing
    Last Post: 02-23-2007, 11:21 PM
  3. GE Fanuc Series 18-M
    By MGT in forum Fanuc
    Last Post: 02-20-2007, 07:02 PM
  4. Fanuc on a Series 2
    By HillBilly in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2006, 07:50 PM
  5. Fanuc Series 10
    By kayleesdad in forum Fanuc
    Last Post: 05-09-2005, 08:30 PM
