586,075 active members*
4,114 visitors online*
IndustryArena Forum: USB, RS232, PARALLEL etc
Page 1 of 5 123
Threads 1 to 20 of 95
Discuss everything USB, RS232, PARALLEL etc here!
  1. RS232 -Null Modem
    Started by lshingleton, 12-04-2022 08:41 PM
    buy, cable, modem, null, pin
    09-07-2023, 03:03 AM Go to last post
  2. Question RS232 for data collect with Arduino.
    Started by LeDavida, 12-28-2020 12:59 AM
    arduino, data, forum, haas, rs232
    02-16-2023, 10:27 AM Go to last post
  3. Testing RS232 port
    Started by sudsy, 08-26-2022 05:16 AM
    controller, machine, port, rs232, send
    09-23-2022, 07:09 AM Go to last post
  4. Communication Error
    Started by JDtz88, 06-16-2022 07:47 PM
    business, cnc, communication, error, software
    06-16-2022, 07:47 PM Go to last post
  5. Omax RS 232 Communications Protocols
    Started by Betek, 08-09-2021 10:57 PM
    controller, omax, pump, rs232
    08-09-2021, 10:57 PM Go to last post
  6. Breakout board advise please
    Started by OldButNewToMe, 06-01-2021 07:43 PM
    bob, controller upgrade, ethernet, smooth stepper, usb
    06-01-2021, 11:56 PM Go to last post
  7. Vista Pendent issues
    Started by MARV, 05-06-2021 04:25 AM
    cnc, issue, lee, pendent, plugin
    05-06-2021, 07:09 PM Go to last post
  8. Transfer cable pin layout
    Started by Fireater, 04-28-2021 06:37 PM
    04-28-2021, 06:37 PM Go to last post
  9. pcie to peripheral adaptor driver
    Started by cruz03, 01-18-2021 07:04 PM
    driver, install, installed, mach3, pci
    01-18-2021, 07:04 PM Go to last post
  10. Ethernet connection by CNC4PC
    Started by Dr X, 12-21-2020 12:05 AM
    12-21-2020, 12:05 AM Go to last post
    11-20-2020, 08:50 AM Go to last post
    10-12-2020, 01:27 AM Go to last post
  11. Exclamation simodrive 611a communication parameter
    Started by vk_rathi, 08-19-2020 08:01 AM
    connect, procedure, siemens, software, suggest
    08-19-2020, 08:01 AM Go to last post
    07-22-2020, 04:33 AM Go to last post
  12. Need help with Yasnac MX-2 DNC (Drip feed) error
    Started by nweisz, 07-09-2020 12:10 AM
    cp-02 error #39, dnc error, drip feed error, matsuura mc-760v, yasnac mx2
    07-22-2020, 02:06 AM Go to last post
    07-09-2020, 02:01 AM Go to last post
  13. dead computer? (parallel port)
    Started by DHay13, 04-26-2020 09:34 PM
    ago, cnc, computer, parallel, years
    04-27-2020, 02:45 AM Go to last post
  14. pci parallel port
    Started by s_tones, 02-04-2015 01:27 AM
    03-09-2020, 12:43 AM Go to last post
  15. PCI-Express Parallel Port Adaptor card - Will it work ?
    Started by roli_bark, 07-05-2010 06:05 AM
    2 Pages
    1 2
    03-09-2020, 12:05 AM Go to last post
  16. Question CNC Parallel Port - Unknown Pins! (Mach3)
    Started by Butterhat, 02-26-2020 02:09 AM
    cnc router, mach3, parallel
    02-27-2020, 07:31 PM Go to last post
Page 1 of 5 123
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
