587,781 active members*
2,670 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jun 2004
    22
    Bridgeport Value?
    I have this Bridgeport available to me. It looks like it's in fairly
    rough shape. If anyone can give me some info on it
    especially what the value maybe in this condition.
    that would be great.
    Brad Stilley
    P.S. you may remember I'm the guy that had the
    free Bridgeport that turned out to be a cincinatti
    shaft grinder. Well this time I was smart enought
    to get pictures first.
    Attached Thumbnails Attached Thumbnails bridgeport-1.jpg   bridgeport-2.jpg   bridgeport-3.jpg   bridgeport-4.jpg
    Nov 2004
    3028
    WoW! A round ram! I wonder what the serial number is. A long time ago BPT tried to find the oldest machine. I belkieve they found serial number 10. A lot of rust. Power feed is missing a motor. How are ways? How does the head sound?
    George
    May 2005
    1810
    Is that an M-head with a J-head spindle?
    Machintek - did they come this way? Sure looks like a J-head where a M-head is supposed to be...
    I would guess it would E-bay as pictured for about $400 - just my guess.
    Cleaned up and painted - on a good day - $850.
    Re-built - not worth the effort and cost (not to re-sell).
    Scott
    Jun 2004
    22
    I haven't seen it personally yet. It's about a hour and
    a half drive for me. So I figured i'd get some opinions first.
    The machine is not under power so I will have no Idea
    as to the condition of the head untill I buy and fire it up.
    If I buy it.
    The guy wants $750 for it by the time I move it I'll
    have over a grand into it. Sounds like it not worth it.
    Although the guy is moving so he might be motivated
    to drop the price.
    I only know the condition by the pictures. The
    Chunks missing from the table tell me it probably
    was not lovingly cared for. It currently resides
    up in the mountains so the shed its in is a moist
    environment.
    I'll try to find the serial. It its 000000001 it
    would be worth the trouble. But unless someone
    suggests otherwise I'll not waste my time going to look
    at it.
    Aug 2004
    2849
    Tell $100 and you won't charge him for carrying off the scrap.
    May 2005
    1810
    If you don't have a mill and want one, $500 would be reasonable if the spindle spins and there's not too much damage to the ways or inside the head - which is impossible to know until you get into it. But it's really hard to say how much damage the rust has caused - the interfaces that can't be seen will be worse than the exposed surfaces - especially if it has been rained on. If the rust is caused by condensation or humidity, then the hidden areas will likely be better than the exposed surfaces. The condition of the ways doesn't look too good, but pictures can't replace a good visual inspection.
    Obviously it would require some serious TLC (duh) but it would get you a milling machine and some valuable experience - if you have the time and motivation. It's a lot of work.
    $750 as is seems a bit much based on the pics - hold your money and keep checking Ebay. $1000 will get you a reasonable machine if you are patient.
    Scott
    Nov 2004
    3028
    I purchsed (a year ago) a 2J head series 1 std in good shape for $850.00. I was patient and waited for the right machine at the right price.
    This machine is high considering the amount of hours you will have to put in to get it in resonable working condition.
    The M head had no qill feed. It was a small die-makers head.
    With the type of power feed I see on this machine, it is very reasonable to also see a J head on it. I think it was manufactured toward the end of the round ram production run.
    It would still be interesting to know the serial number. The first machines had the serial number on the door. Later it moved to the top of the knee.
    George
    May 2005
    1810
    I love the insight you offer, George! Many thanks for posting. I worship your posts on Bridgeports.
    Smird - if you have $1K to spend, keep your money and be patient. You will find a machine in much better condition if you keep up the search. I search all the time for another machine, so if I run into what looks like a good deal, I will give you the heads up.
    I think I would pass on this one unless he comes down on the price ($400-$500). At minimum, you will likely spend $600 to fluff up a machine that's in reasonable condition - and the machine pictured is not what I would call reasonable condition - but it's hard to say by just looking at pictures.
    Scott
    Mar 2004
    439
    Machinetek-
    If my memory is correct, the earliest serial number bridgeport is in the American Precision Museum in Windsor Vermont. It was re-scraped and rebuilt by a friend of mine, and I think that it is earlier than #10. Here is the website for the museum, and I highly reccomend thier annual show, which usually occurs in October.
    http://www.americanprecision.org/
    I'll have to check through my digital pictures, as I may have a picture of the Bridgeport. It was a small machine, and used a #2 morse taper. I think it was a 1/2HP head, and I think that it even had a shaper attachment on the back of the round ram.
    Keith
    Jun 2004
    22
    Well if the price comes down. I may buy it then. The guy is having a garage sale this weekend and thinks it will sell then. He's firm on the price. Maybe once his house sells and he's a little more desparate then he'll negotiate. I found more info at http://www.lathes.co.uk/bridgeport/page15.html
    looks like it was the second model they made. If anyone want to buy this for $750 let me know and I'll forward the info.
    Thanks for everyones help.
    Brad
    May 2005
    1810
    SO???
    What did ya do? Did ya go look at it??
    C'mon - don't leave us hanging!! (chair)
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Jun 2004
    22
    I did go look at it, got back late last night. It's definitely a pass.
    It was in really bad shape. I could not fire it up. No Elec.
    wired for it.
    But in moving the table it felt crunchy for lack of
    a better term. Definitely not smooth. There a couple of big
    chunks out of the table and a lot of rust ( mostly on the surface
    though).
    I don't have a lot of experience with the larger machines.
    I have a taig and a Harbor Freight round column mill I just finished
    converting. I'll probably sell the Taig to put some more money in my
    pocket so I can get a good new Bridgeport clone or a used BP
    in excellent condition. I'm not very patient and I think having
    a machine that I need to rebuild and then convert to cnc. Will
    be too much.
    Brad Stilley
    P.S. I did tell him when he's ready to move and if he still
    has hit let me know I'll come take it off his hands.
    Feb 2005
    25
    FWIW I picked up an R2E3 series I bridgeport with a Boss8 control for $1300. It was said not to be working. It had a few issues - but the main one was that the brake in the spindle housing was out of alignment - a couple of spacers later and it was good to go. The control had a few quirks (servos fired up fine, I think it was actually the lube being clogged that caused the problem). Anyway, about $1,500 later it has a full PC/EMC/Geckodrive retrofit and is holding parts easily to less than a thou.
    I would say even $300 is too much for this machine, IMO.
    May 2003
    130
    Fastturbovet if I read the post correctly you retrofitted the R2E3.If so did you keep the parts you removed?I have an R2E3 that is stock and working plus I have another one on the way, it should be in the shop within the next 2 weeks.Would you be interested in parting with the parts?
    May 2005
    1810
    smird -
    Gotta check this out -
    http://cgi.ebay.com/ws/eBayISAPI.dll...519485538&rd=1
    Decent machine - bidding at $1K, buy it now for $1200. serial #79226 with variable speed head (probably NOT original, but who cares). I am sure it would need work, and it is located in NY.
    Just keeping an eye open....
    Scott
    Scott
    Jun 2004
    22
    Scott,
    looks good, I'm putting my taig mill and my picza scanner
    up for sale this weekend. If they go quick enough I'll make a
    bid for it. Any one know the cost to hual one of these accross
    the U.S. I'm in So. Cal.?
    I've allready have the controller and motors done. Gecko Drive
    with 1200 in oz motor. It's on my Mill/Drill right now.
    Brad
    May 2005
    1810
    Smird -
    If you gotta ship it to CA - forget it. Shipping and rigging would likely be more than the machine. I would guess about $300 for rigging/loading and $800 for the truck/freight.
    I will keep you in mind if I come across a what I think is a reasonable deal in SoCal.
    Scott
    Feb 2005
    49
    What does evreyone think a boss 5 machine is worth
    I will know next week if it is still avaiable like i said before people just want to take off the motors off and put on handles :banana:
    Aug 2004
    2849
    I don't really trust people that don't show you more pics...like pic of the ways, closer views that are clearer. Too much of the "trust me" is involved.
    Feb 2005
    49
    Angry hers how the bidding process goes
    i oferd 500or 600 hundred thay cALLED BACK AND SAID THAY GOT 700 CAN I BID MORE I TOLD THEM 75O THAY SAID AFTER 10 AM I WOULD KNOW THAY STILL DID NOT CALL NOW WHAT KIND OF A SALE IS THAT
Page 1 of 2 12
  1. Noise in Bridgeport 2J head (audio file included)
    By daytrader in forum Bridgeport / Hardinge Mills
    Last Post: 08-03-2016, 07:03 PM
  2. Bridgeport EZ Trak Flashdisk question:
    By marx911 in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2010, 02:09 AM
  3. How do you make Bridgeport execute program?
    By Bill Gillen in forum Bridgeport / Hardinge Mills
    Last Post: 06-14-2005, 02:26 PM
  4. Bridgeport Eztrack Series II -Ferror Program
    By yuso in forum Bridgeport / Hardinge Mills
    Last Post: 05-23-2005, 06:44 PM
  5. Bridgeport CNC toolholders
    By snaggletto in forum Bridgeport / Hardinge Mills
    Last Post: 07-17-2004, 02:38 AM
