587,308 active members*
3,675 visitors online*
Results 1 to 10 of 10
    Feb 2005
    101
    Bridgeport Explorer CNCs
    i have recently gotten a line into a few Bridgeport Exporer CNC mills that are pretty close by to me. I can't seem to find any information about them on the web. I've inquired with bridgeport, but they havn't gotten back to me yet. Does anyone know anything about these machines? Any info would be greatly appreciated! Thanks!
    Feb 2005
    2
    Bridgeport cnc
    Hi ,
    I bought a serie 1 bridgeport, and want to make it cnc.
    Do you have some information about it?
    aspecialy the solusion on the z axis.
    and what kind of software i can use.
    Latu
    Feb 2005
    101
    archives
    I would search the archives for info on Series 1 conversions. There is a lot of info there and on other sites on the internet. I'm looking for info about the Bridgeport Explorer CNC's, which are different machines.
    Jan 2005
    1121
    I think the iron is the same as most late boss machines, and assume the control is PC based. I know fvery late they had extended x axis which would be handy. If they are cheap I would buy them were I you, as they should be servo machines with a good electrical cabinet, a recontrol would be fairly easy/cheap and that iron is bulletproof.
    Feb 2005
    101
    bosses
    I actually don't even know much about the Boss mills either. Are they similar to the series 2? Do they have computer controlled spindle speeds?
    I'll have to do more research into the BOSS... is there a reference that talks about the different models? It's too bad bridgeport (or hardinge) doesn't put up reference materials about all these older products... they will probably outlast the company!
    Thanks for the tips.
    Nov 2004
    3028
    I would bet a dinner that the explorer is series 1 CNC iron. The same iron used on the BOSS series machines (3,4,5,6,8, and 9). I do not believe the X travel is extended (still 18 inches). I will check the book tomorrow. What is different is that it has the PC based DX32 control with a color CRT. I installed 3 in schools and one at a plant in MS quite a few years ago. The X axis travel was extended on the BOSS 10, V2XT and the EZTRAKs. All these had series 1 iron. NOT series 1 CNC iron.
    George W.
    Jan 2005
    1121
    IIRC, there were late cnc iron explorers with more x travel, could be wrong, but I don't think so
    Nov 2004
    3028
    Looking over my installs, I have installed 11 Explorers, with the last 3 having a designation of Explorer X26. A friend of mine will look at his book tonight and fax me the specs on this machine. I am interested that if this has extended travel, why I did not notice (or did not remember, too old?), how the extended travel was achieved, or is this a hybrid of series 1 and 2 cnc iron. The explorer 1 was limited to 18 inches in the X travel to keep the weight over the saddle for better accuracy. I wonder what is the weight limitation on this X26 machine.
    George W.
    Nov 2004
    3028
    I was informed that the X travel of the Explorer X26 is indeed 26 inches. I have asked to have the exploded view and parts list as well as spec be faxed to me. When I receive them and review them, I will know the weight capacity and what was changed to achieve the extended travel.
    George W.
    Feb 2005
    101
    aha?
    X26 = 26" X travel? That would explain the strange designation! I wondered how they went from the explorer 1 to the X-26.
    Great info!
    james
  1. Bridgeport EZ Trak Flashdisk question:
    By marx911 in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2010, 02:09 AM
  2. Bridgeport Series 1 Retrofitted!
    By biomed_eng in forum CNC Machine Related Electronics
    Last Post: 08-25-2006, 02:19 AM
  3. How do you make Bridgeport execute program?
    By Bill Gillen in forum Bridgeport / Hardinge Mills
    Last Post: 06-14-2005, 02:26 PM
  4. Bridgeport Eztrack Series II -Ferror Program
    By yuso in forum Bridgeport / Hardinge Mills
    Last Post: 05-23-2005, 06:44 PM
  5. Bridgeport CNC toolholders
    By snaggletto in forum Bridgeport / Hardinge Mills
    Last Post: 07-17-2004, 02:38 AM
