587,348 active members*
5,253 visitors online*
Results 1 to 1 of 1
    Apr 2007
    7
    Y axis pre-alignment
    hello, I`m about to weld the last part of my gantry mill before I send to stress relief.
    I have 3 set bolts on the Y axis so after welding I can fine pitch and roll the axis in reference to X axis, but I cannot Yaw. The fine tune of the Yaw will be on the X axis itself.
    I would like to weld with minimum error possible, so with minor adjustment on the set bolts I can square the gantry.
    How can I do this pre-alignment to tack weld the Y axis as near as possible square to X axis?
    Sorry for my rusty English
    Attached Thumbnails Attached Thumbnails DSC04670.jpg   DSC04671.jpg   DSC04674.jpg   DSC04675.jpg
  1. Parallel axis alignment
    By Yovav in forum Mechanical Calculations/Engineering Design
    Last Post: 08-15-2013, 04:09 AM
  2. minitech axis out of alignment
    By roger_e in forum Benchtop Machines
    Last Post: 12-28-2009, 12:46 AM
  3. xand y axis out of alignment
    By roger_e in forum Vertical Mill, Lathe Project Log
    Last Post: 12-27-2009, 05:16 AM
  4. 5 Axis Alignment
    By Tazzer in forum Centroid CNC Control Products
    Last Post: 02-25-2007, 09:31 PM
  5. x-axis alignment
    By FLUTE HEAD in forum Vertical Mill, Lathe Project Log
    Last Post: 07-10-2005, 03:05 PM
