587,375 active members*
3,123 visitors online*
    Jul 2004
    148
    x-axis alignment
    specs: harbor freight round column benchtop mill. What would be a good way to make sure that the x-axis ballscrew is running parallel and concentric to the x-axis ways? I could run a test indicator along the face of the ball nut housing to get the housing parallel to the x-axis, but what about alignment? I'm not so sure that the holes drilled for the original x nut mount were aligned correctly. If they were then I could use coutersunk socket head screws that would sort of "self align" to the bottom of the x nut mounting holes, being that they were drilled and have a taper from the drill bit. What approach do others use for this process?
    May 2005
    90
    Have a look at www.industrialhobbies.com , they have a series of steps that show setting up an x-axis on their mills.
    Jay
    Jul 2004
    148
    Thanks, had a brief look at the site. nice site. I'll keep lookin through.
  1. Laser spindle alignment?
    By cgallery in forum DIY CNC Router Table Machines
    Last Post: 12-22-2014, 01:01 AM
  2. Mini Mill alignment
    By tpicker1 in forum Benchtop Machines
    Last Post: 05-12-2004, 10:36 PM
  3. Alignment, backlash, limit switches etc
    By CNC Brute in forum DIY CNC Router Table Machines
    Last Post: 01-18-2004, 03:05 AM
  4. Alignment and squareness issues
    By boxwood in forum DIY CNC Router Table Machines
    Last Post: 08-24-2003, 02:20 AM
