587,125 active members*
5,650 visitors online*
Results 1 to 4 of 4
    Jul 2008
    139
    Wizard to find centre of circular bit of metal?
    I've had a quick google about without much luck - most circle related wizards see to focus on touching the inner eges of a hollow circle (eg pipe/tube) , but what I seek is a Mach3 Mill wizard where it'll find the centre of a piece of circular material by probing the outside edges of the material in a few places.
    Does such a wizard exist?
    Jul 2005
    969
    check hoss probe script i am sure it can do it
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Jul 2006
    40
    Hi Hank,
    A Tormach owner, Maurice Proulx posted a wizard (Circular Boss Center Point)on the Yahoo Tormach group (files section).
    This add on for Mach 3 is increadibly useful.
    It is compressed using RAR compresssion - so you have to have a RAR extract utility to open it.
    Once I downloaded this utility, I found all kinds of uses for it.
    Best regards;
    Art Pentz
    Dec 2007
    10
    Quote Originally Posted by HankMcSpank View Post
    ...., but what I seek is a Mach3 Mill wizard where it'll find the centre of a piece of circular material by probing the outside edges of the material in a few places.
    I do not know if a wizard exist, i made a macro that does many functions.
    This is the "Shaft" extract
    To run it you have to link to a user button or include in yours other functions.
    Take care, when you run the shaft procedure, a check is made to be sure that the gauge is not already engaged, than to continue the operation you must engage it (ground it like a push button).
    'find shaft center and calculate diameter
    Sub Shaft
    Option Explicit
    Dim TS As Single
    Dim FeedCurrent, Xcurrent, Ycurrent , Zcurrent As Single
    Dim XCenter, YCenter, XPos1, XPos2, YPos1, YPos2, XNew, YNew, ZNew, ZPos1,ZSafe As Single
    Dim responce As Integer
    Dim Max_move , Shaft_D As Double
    Const ZClear = 10 'Safe Z
    Const XMove = 4 'Max probe search
    Const YMove = 4 'Max probe search
    Const FSlow = 50 'edje search speed
    Const Tout = 15 'Time out in seconds
    Const Probe_Radius = 3.15 '
    If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Code "(Probe grounded, check connection and try again)"
    responce = MsgBox ("Probe grounded, check connection and try again" , 0 , "Probe **ERROR**" )
    Exit Sub
    End If
    Rem VBScript To shaft center
    Max_move = Question ("Enter max shaft diameter, min value 1 mm")
    If Max_move < 1 Then
    Code "(Diameter < 1, Function abort)"
    Exit Sub
    End If
    If Touch ("(Touch the Probe to start Shaft center function)") Then Exit Sub
    Code "F" & FSlow
    Rem Probe up
    YNew = YCurrent + Max_move
    Code "G31 Y" &YNew
    While IsMoving()
    sleep 100
    Wend
    YPos1 = GetVar(2001)
    YNew = YPos1 - 0.5
    Code "G0 Y" &YNew
    ZNew = ZCurrent + ZClear
    Code "G0 Z" &ZNew
    YNew = YPos1 + Max_move + (Probe_Radius * 2) + 2
    Code "G0 Y" &YNew
    Code "G0 Z" &ZCurrent
    Rem Probe down
    YNew = YNew - Max_move - Probe_Radius
    Code "G31 Y" &YNew
    While IsMoving()
    sleep 100
    Wend
    YPos2 = GetVar(2001)
    YNew = YPos2 + 0.5
    Code "G0 Y" &YNew
    Code "G0 Z" &ZNew
    YCenter = (YPos1 + YPos2) / 2
    Code "G0 Y" &YCenter
    Rem Probe Left
    XNew = XCurrent - Max_move - (Probe_Radius * 2) 'probe to left
    Code "G0 X" &XNew
    XNew = XNew + Max_move + Probe_Radius
    Code "G31 X" &XNew
    While IsMoving() 'wait for the move to finish
    sleep 100
    Wend
    XPos1 = GetVar(2000) 'get the probe touch location
    XNew = XPos1 - 0.5
    Code "G0 X" &XNew
    Code "G0 Z" &ZNew
    Rem Probe Right
    XNew = XPos1 + Max_move + (Probe_Radius * 2) + 2 'probe to right
    Code "G0 X" &XNew
    XNew = XNew - Max_move - Probe_Radius
    Code "G31 X" &XNew
    While IsMoving()
    sleep 100
    Wend
    XPos2 = GetVar(2000)
    XNew = XPos2 + 0.5
    Code "G0 X" &XNew
    Code "G0 Z" &ZNew
    XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
    Code "G0 X" &XCenter 'rapid move to the x center location
    While IsMoving ()
    sleep 100
    Wend
    Shaft_D = (XPos2 - XPos1) - (2 * Probe_Radius)
    Code "(Shaft diameter = " & Shaft_D & " mm)"
    Code "F" &FeedCurrent 'restore starting feed rate
    End Sub
    'Wait for a probe touch - untouch
    Function Touch (Tshow As String) As Integer
    Code Tshow
    'wait probe touch
    TS = Timer
    Do
    If Timer - TS > Tout Then
    Code "(Function Time Out, no probe touch detected)"
    responce = MsgBox ("Function Time Out, no probe touch detected" , 0 , "Probe **ERROR**" )
    Touch = 1
    Exit Function
    End If
    sleep 100
    Loop Until GetOemLed (825) <> 0
    'short delay
    sleep 1000 'let user to untouch probe
    'Wait for probe untouch
    TS = Timer
    Do
    If Timer - TS > 2 Then
    Code "(Function Time Out, continuous probe touch detected)"
    responce = MsgBox ("Function Time Out, continuous probe touch detected" , 0 , "Probe **ERROR**" )
    Touch = 1
    Exit Function
    End If
    sleep 100
    Loop Until GetOemLed (825) = 0
    Touch = 0
    End Function
    Regards
  1. tip not at the centre
    By david_geng in forum Digitizing and Laser Digitizing
    Last Post: 02-26-2009, 04:03 PM
  2. Looking for 3 pins metal circular connector
    By rainman in forum Want To Buy...Need help!
    Last Post: 02-09-2009, 02:59 AM
  3. Finding the centre of an arc
    By Robin Hewitt in forum G-Code Programing
    Last Post: 03-28-2008, 02:02 PM
  4. Nesting Wizard, Mach3 internal wizard.
    By thuffner3 in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2007, 03:38 AM
  5. Where can i find metal lathe spare parts in brisbane?
    By rhino in forum Australia, New Zealand Club House
    Last Post: 05-09-2006, 08:02 AM
