I know, fortunately the water cooled spindles do not require a large volume cooling line, most people are using fish-tank pumps and a 5-gal bucket!
I just want a fail-safe system built into the machine!
"ZFS-05S 20mm Male Thread Metal Shell Water Flow Sensor Switch" requires 100V, and I only want to use 12-VDC controls.
AC lines are problematic within CNC's due to noise!
With all the people building & using CNC's, I'm shocked that this type of component doesn't exist!
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
