Attachment 389698
All soldered now. I'm going to setup my UCCNC test system this weekend, update UCCNC and have a play with the board.
Do I need and update to UCCNC to enable it to see the UD1 correctly?
matth,
So actually we can use ribbon cable assembly or linker between UB1-UD1, but linker need to be soldered. I just knew that.
Yes, you can use either.
I think it’s worth soldering the linker as it makes a very neat connection.
The UB1 daughterboard seems to be skewed towards inputs vs. outputs. Is there a reason for that? Any change of a UB2 that is skewed towards outputs??
Because it's designed for ports 4 & 5 on the UC300ETH, which are mostly inputs.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
