587,584 active members*
3,772 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Torq Cut 22 help with a problem
Results 1 to 2 of 2
    Oct 2016
    19
    I have a torq Cut 22 and I am having the problem that when I run a program at the moment it loses and damages the pieces making lines and radii, any idea what it could be.
    a photo to give you an idea
    Quote Originally Posted by christian7r View Post
    I had similar problem some years ago
    It was the postprocesor. I looked for the right one, ant the issue was corrected
  1. '96 Torq Cut 22 communications problem
    By Deltamachine in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2016, 02:23 PM
  2. confirm my suspicion. Torq-cut 22 problem
    By zane in forum Bridgeport / Hardinge Mills
    Last Post: 05-28-2014, 03:53 PM
  3. Torq-cut 22 gear change problem
    By lampguy in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2013, 06:51 PM
  4. Swap problem on a Torq-cut 22
    By Wiseco in forum Bridgeport / Hardinge Mills
    Last Post: 04-08-2011, 11:30 PM
  5. torq cut 22 problem
    By hawk1 in forum Bridgeport / Hardinge Mills
    Last Post: 01-08-2011, 03:15 PM
