NICE of Hardinge.
I have shifted gears on machines that are a bit stubborn. While in ESTOP or machine off (but air ON), I can use 2 pin punches and press the manual spool shift buttons on the solenoid while a second person rocks the spindle back and forth.
I use one pin punch to release the shot pin and while holding that I can press the HI/LOW solenoid to make the ROTAC move the gear plates in the transmission. Once there (the person rocking the spindle will feel the change) release both and make sure the shot pin is engaged again. This can be looked at in the maintenance page.
If this does not work, you have a problem.
Is the shot pin pulling out of the bottom gear plate to allow movement?
Is the ROTAC trying to move the gear plates? It does have orifices to achieve smooth and slow movement,
Are the switches on the ROTAC set correctly?
Are the solenoids good?
Transmission filled with the right oil? It does have a sight glass.
The motor pulls straight up and out of the transmission, then the top plate of the transmission can be removed and you can investigate the situation.
George
