587,311 active members*
3,516 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Taper control in Fanuc control
    Feb 2006
    16
    When taking out a taper, in the past would edit program to remove. I have seen some use a "U" to remove taper. Does anyone know if this acts just on the line it's on or does it change the entire profile
    Mar 2009
    23
    Re: Taper control in Fanuc control
    U value will apply only to line of code it's in, but if you are moving from a linear move into a radius move you must consider if the U value used will exceed the start point needed for the arc of the radius. Control will alarm if the distance exceeds the required travel to make the arc. U negative value will make part smaller as it progresses down the linear move, U positive will make it larger as it travels the length.
    Apr 2009
    7
    I have a Fanuc 11TT control and a G07 code is available to define a virtual axis. I haven't tried it yet (I plan to soon), but you could try to define an X axis perhaps, and make the taper adjustment there. If that is successful, you can then code X as normal. Just a thought...
    Quote Originally Posted by stan Cothran View Post
  1. Replies: 5
    Last Post: 05-31-2019, 05:16 PM
  2. Replies: 1
    Last Post: 02-19-2014, 02:19 AM
  3. Replies: 7
    Last Post: 11-17-2013, 01:46 AM
  4. Cards Support Stepper Motor Driver Control & AC Servo Control.
    By Johnnyatcnc in forum News Announcements
    Last Post: 04-09-2010, 09:57 AM
  5. Replies: 2
    Last Post: 12-28-2007, 04:57 PM
