587,744 active members*
2,988 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 15i control help for (AiCC) (hpcc) high precision contour control programming
    Dec 2007
    3
    Hello,
    I have a question regarding our Matsuura LX-0 with the L-Tech 15i control. I am wanting to program an interpolation of a circle at the most highest accuracy possible using hpcc (AiCC) G05.1 Q1 R1. Listed below is an example of what we are currently doing. Is there a better way of doing this? Like programming the circle in quadrant's instead of full circle? Or arc in at a 45 degree instead of 0 or 90 degrees? Program using NUMBRS? Were getting a little to much out of roundess. The part itself is a casting with an partial opening on the pocket circle which I am arcing in at and out to prevent any "bumps". Our main goal is to achieve the most circular round part as possible with minimal runout. Thank You for your time.
    T1M6
    G0G90G54X0Y0M3S30000
    G43H1Z1.0M8
    G05.1Q1R1
    G1Z.1F200.
    Z-.5F100.
    G91G1G41D1X-.1Y-.1F120.
    X-.1Y-.1
    G3X.2Y-.2I.2J0
    G3X0Y0I0J.4
    G3X.2Y.2I0J.2
    G0G90G40X0Y0
    G0Z3.0M9
    M5
    M30
    Mar 2007
    122
    Just because you have R1 in the program doesn't mean that it will be the best best accuracy for what you are doing. I am doing bore grinding on a vertical grinding centre using R8 in AI NANO and this seems to be giving me the truest bore. You may want to experiment R1 - R10 to see what is best for you. Also if this is cast material you will want to rough the hole first to make it is round before you start finishing, because if you start out of round you will end out of round.
    Sep 2007
    49
    Gibbmaster,
    Could you explain hpcc and the G05.1. I'm not familiar with it and the books I have don't explain it.
  1. Need to replace Dynapath 20 control with new control
    By Cycle Start in forum Knee Vertical Mills
    Last Post: 08-08-2010, 09:14 PM
  2. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
  3. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
  4. BobCADCAM Layer Control / Snap Control
    By jonbanquer in forum BobCad-Cam
    Last Post: 01-21-2006, 10:10 PM
  5. Change - from linear path control to CNC path control
    By Fidibus42 in forum CNC Machine Related Electronics
    Last Post: 12-04-2005, 05:43 PM
