587,794 active members*
3,204 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Super X3 high speed spindle
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    May 2007
    10
    Super X3 pulley conversions
    Hope this helps somebody trying to speed up their Super X3:
    for US ordering
    QTC410 - Component Data Base
    search for part no. QPMHTD5S15040F08
    you will have to bore out the diameter to 14mm and key to fit the machine.
    this means buying a broach and press to key pulley. Also you will probably want to tap a set screw into into it.
    Belt is also req'd:
    QB-HTD5-0450-15
  2. #22
    Mar 2006
    13
    Re: Super X3 high speed spindle
    I realize this thread is years old, but a company called 'Misumi' is available online, where you can order pulleys that fit your needs. No more need to order a pulley in a stock configuration, then have to machine it. Just order it the way you want it. Total cost is far less and its at your door in about a week. I used them to create two new pulleys for me, for my SX3. They also have a belt calculator, so ordering the right belt is a breeze.
Page 2 of 2 12
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. high speed spindle
    By redridertwo in forum MetalWork Discussion
    Last Post: 02-14-2013, 02:07 PM
  3. High speed air spindle
    By pebbert in forum MetalWork Discussion
    Last Post: 11-08-2008, 09:25 PM
  4. High speed spindle
    By yngndrw in forum MetalWork Discussion
    Last Post: 06-26-2008, 09:19 PM
  5. Haas Super VF-4 High speed
    By binzer in forum Haas Mills
    Last Post: 07-25-2007, 09:27 PM
