587,917 active members*
3,300 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Single Point Burnishing on Tsugami
Results 1 to 2 of 2
    Apr 2005
    21
    Hello,
    Anyone know of a good short single point burnishing tool? Most are over 2.5" long past the tool holder which may be prohibitive for setup with our Tsugami BS12. Part is 3/8 OD and we need to burnish a .75" section for interface with a T25 Turcon seal (http://www.trelleborg.com). Shooting for a 50% Rmr(c) finish (bearing surface finish calc'd as percentage of surface located at 10% below peaks).
    Also, for this type of work, is the single point spring loaded burnishing tool our best bet or should we be using a rotary tool (even bigger unfortunately)? The only tool that looked promising is a round bar rotary tool that we could put into a conventional boring bar holder perhaps as a second op for these parts....but I would MUCH prefer to do all of the work on the screw machine.
    Thanks for your time.
    Jason
    Jan 2008
    12
    cogsdill tool is the best I know of.
  1. Single point threading
    By DragnsBane in forum MetalWork Discussion
    Last Post: 10-06-2007, 05:25 AM
  2. Single Point Threading Inserts
    By John3 in forum Polls
    Last Post: 08-06-2007, 03:45 PM
  3. Single point vs. multipoint threadmilling
    By RoboElvis in forum MetalWork Discussion
    Last Post: 03-27-2007, 08:11 PM
  4. Single point gear cutting
    By jguillen08 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-07-2006, 04:07 AM
  5. Single point threading
    By kdoney in forum Mach Mill
    Last Post: 02-09-2006, 06:13 AM
