586,991 active members*
3,372 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Why do I keep stripping the inside of the lead screw drive gear?
    Sep 2008
    107
    Hello,
    I was turning down a 2" piece of UHMW polyethylene with my Microlux 7x14 lathe, at 1000 rpm, using automatic carriage feed, and taking light cuts, when all of a sudden the lead screw stopped turning.
    I took the cover off, changed out the damaged 80 tooth drive gear, and then it worked for a few more minutes before the same thing happened again; in each case, the keyway simply gouged out the inside of the plastic gear.
    Has anyone else ever had this problem? I wonder what could be going on here?
    Nelson
    Sep 2008
    107
    Ok, when I put another new drive gear on the lead screw, I cannot turn it at all by hand (I already removed the small gear that drives it). So it looks like the lead screw is basically "frozen".
    Has anyone else had that happen before? What could cause this to occur?
    Oct 2006
    14
    Sounds like you might have a binding issue with your lead screw at either the pillow block or the halfnuts. It should turn by hand without too much effort.
  1. How to mount lead screw inside a bearing?
    By CuttersCov in forum DIY CNC Router Table Machines
    Last Post: 08-13-2011, 01:25 PM
  2. How do you mount a lead screw/lead nut?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 11:10 PM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. Ball Screw or Lead Screw? Which is Better?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 02:49 PM
