587,141 active members*
4,197 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How do you mount a lead screw/lead nut?
    Nov 2008
    16
    I'm sure this is very simple to all of you but it will really help me out. I'm in the planning stages and want to make sure I know what I need before I need it so I can make educated decisions on parts.
    Does anyone have a detailed drawing of examples of how some standard lead screws or simple threaded rod are attached to the moving axis and the stationary mounts? Do you all use specific lead screw mounting bearings that have mounting holes on them and a bearing built in, or are there other common methods for mounting the lead screw/bearing and the leadnut? Looking for both super cheap methods and high precision/high value methods.
    thanks
    Jesse
    Feb 2007
    4553
    Talking Start looking in the dumpster.
    http://www.dumpstercnc.com/
    Welcome to the Zone.
    Jeff...
    Mar 2007
    574
    http://www.cnczone.com/forums/showth...=13593&page=44
    a different better kind of screw
    about the position of the screw closer to the gravity center is better
    how to do it ?
    the best solution is to use 2 lead screw /axe and one servo the 2 servo solution implied a high level of knowledge in electronique and more (much more) money
    lucien
  1. How to mount lead screw inside a bearing?
    By CuttersCov in forum DIY CNC Router Table Machines
    Last Post: 08-13-2011, 01:25 PM
  2. Using different tpi lead screw for x y
    By Bill Davis in forum DIY CNC Router Table Machines
    Last Post: 08-17-2006, 12:06 AM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. Lead Screw?
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 02-26-2004, 04:32 PM
