586,792 active members*
3,214 visitors online*
Results 1 to 8 of 8
    Oct 2007
    142
    My Anilam 3300mk quit
    I have an Anilam 3300mk on a 1998 HH Roberts bed mill. After months of trouble free service I am getting a "Z lag error" when I try to home the mill. If I try to move the bed I get the same error for that axis. The servos turn easily and the bed moves freely. The drive belts are in good shape and I cleaned the servo connections. The controller boots up normally. What should I do next? (Before I call in the service guy.)
    Thanks in advance
    Matt
    Help
    I would contact this guy. He will be able to help you.
    Anilam-Acu-Rite Companies Inc.
    Customer Service
    Gerald W. Bouvier, Jr.
    Phone # 716 661 1883
    Fax # 716 661 1884
    [email protected]
    Oct 2007
    142
    Thanks, I got it going yesterday, But I will keep his contact info.
    Matt
    Help
    Hi Matt,
    You might want to back up your parameters if you haven't done so already. If you contact Jerry he can send you the software and give you instructions on how it's done.
    If you computer ever crashes and you don't have them you are in big trouble.
    John
    Oct 2007
    142
    Hi John.
    I already have the boot disks, do I need something else?
    Thanks again
    Matt
    Software
    Hi Matt,
    If you or anyone else has modified any of the parameters and your system crashes then when you run the boot discs it will revert to the original parameters shipped from the factory.
    There is a backup program that Jerry can E-mail to you that will allow you to backup your current parameters.
    It would be well worth a call to Jerry to have him explain this and other items that may be of use with your system.
    I am not an expert but did go through some work on the software on a couple of Seiki XL 3 Axis CNC Mills with Anilam 1100M controls on them.
    John
    Oct 2007
    142
    Thanks, I'll do that monday
    Matt
    Jan 2010
    23
    I am looking for a Anilam 3300 Mk control system for parts. Any help would be appreciated. Please call Larry at 801 216 4576. Thank you
  1. Amilam 3300MK
    By Durby in forum DNC Problems and Solutions
    Last Post: 04-14-2013, 07:38 PM
  2. Anilam 3300MK
    By Buried in forum DNC Problems and Solutions
    Last Post: 05-02-2012, 05:36 PM
  3. Anilam 3300mk Problem
    By quincy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-15-2011, 07:37 PM
  4. Any experience with Anilam 3300MK control?
    By CNCBoss in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2011, 02:01 AM
  5. V22 Quit Running
    By TZ250 in forum BobCad-Cam
    Last Post: 02-14-2008, 02:06 PM
