586,766 active members*
8,596 visitors online*
Results 1 to 10 of 10
    Jun 2007
    32
    tool offset for concave convex shapes
    Any way to let Mach3 know that it has to take into account the tool diameter when machining a concave or convex shape? See drawing attached.
    G41 and G42 work left and right, I need to brake the tool advance or accelerate it depending if it is climbing or going down.
    No, you'll need some 3D CAM software for that.
    Jun 2007
    32
    does anyone knows such a software?
    How much do you want to spend? Are you surfacing the whole part, or just cutting a slot with that shape?
    Jun 2007
    32
    I want to spend zero or close to it. It is only for a hobby.
    Freemill at www.cncportal.com What about the second question I asked?
    Jun 2007
    32
    It is a wide surface. I will write a VB software for my application. Thanks for your help
    If you have an .stl model, Freemill will write the code for you.
    Jul 2003
    1220
    Is this 2D or 3D and is the cutter a end mill with a ball nose?
    Sep 2003
    1113
    Take an stl file - through the demo version of STLWORK2 - You can account for the tool diameter (endmil/ball etc - you specify) and even cut in waterline -- or slab if you like.
    No VB programming required - you gotta like that
    But if you want the purchased version I recall its about 125 bucks- so not free - but affordable. It will do a demo cut run for you too - let you QC the code.
    Not associated - Just like it. [IMSERV - they advertise on the 'zone]
    http://www.cadcamcadcam.com/index.as...PROD&ProdID=15
    :cheers: Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  1. Tool Offset (G45,G46,G47,G48)
    By jorgehrr in forum G-Code Programing
    Last Post: 11-13-2007, 08:54 AM
  2. custom tool shapes in simulator
    By inflateable in forum EdgeCam
    Last Post: 09-27-2006, 02:27 PM
  3. Tool offset ...
    By patrickb in forum Fanuc
    Last Post: 08-21-2006, 04:53 PM
  4. Tool Offset
    By 3rdcoast in forum Mach Software (ArtSoft software)
    Last Post: 05-19-2006, 07:08 PM
  5. Tool offset collars?
    By mgamber in forum Benchtop Machines
    Last Post: 09-13-2005, 07:16 PM
