587,754 active members*
3,037 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 750 - Alarm 40-33 Output/Fuse Failure in APC Rack 0
    Jun 2022
    Unhappy Arrow 750 - Alarm 40-33 Output/Fuse Failure in APC Rack 0
    Hi everyone!
    I have Cincinnati Acramatic 2100E Arrow 2 and after changing the battery of the RT board 2379A02
    This error come up Alarm 40-33 Output/Fuse Failure in APC Rack 0
    RT-Board : PN : 3-424-2379A02
    BIOS : Award v 4.51pg (ROM PCI/ISA BIOS (2A5LED42))
    We have checked the 24V and fuses but everything is correct
    We made the following configuration in the BIOS :
    ONLY FOR 2379A02
    BE AWARE (SPECIAL CARD): Before you put an AT powersupply to THIS RT Card you must change some Pin options on the card.
    Not respecting this procedure will probably destroy the card.
    This is the procedure:
    - Take a picture of the RT card before doing anything on it, to have a backup PIN configuration.
    - Remove the JPP pin
    - Put a PIN between 2 and 3 on JP2
    - put the P8 and P9 powersupply cord on the RT CARD, the black cables must be in the middle
    - Put the VGA Card
    - Power on the power supply
    At this stage you must see the starting boot, just press the correct button to access to the bios settings.
    - Standard CMOS setup:
    * the primary master/slave and secondary master/slave must be = NONE
    * The drive A and B must be NONE
    * Hald on= All but Keyboard
    - Bios features setup:
    * virus warning disabled
    * cpu internal cache enabled
    * external cahe enabled
    * quick power on self test! enabled
    * boot sequence A C SCSI
    * swap floppy drive disabled
    * boot up floppy seek disabled
    * boot up numlock status on
    * memory ecc function disabled
    * type matic rate settings disabled
    * typematic rate chars sec 6
    * type matic delay 250
    * security option setup
    * pci/vga palette snoop disabled
    * os select for dram non OS2
    * hdd smart capability disabled
    * video bios shadow disabled
    * C***** disabled (2 lines)
    * D***** disabled (4lines)
    - Chipset features setup
    * dimm 1... Normal
    * dimm 2... normal
    * sdram ... 3
    * video bios cacheable enabled
    * system bios cacheable disabled
    * memory hole... disabled
    * cpu to pci... enabled
    * pci dynamic... enabled
    * pci master.... enabled
    * pci delay... enabled
    * pci master .... enabled
    - Power management setup
    * power management disabled
    * pm control.... yes
    * video off methos DPMS
    * video off... suspend
    * stand by mode disabled
    * suspend mode disabled
    * hdd power on disabled
    * resume ... disabled
    * from IRQ3 to IRQ7 = Primary
    * IRQ8 disabled
    * from IRQ9 to IRQ 12 secondary
    * IRQ13 primary
    * IRQ14 primary
    * IRQ15 disabled
    - PNP/PCI configuration
    * Resources control... Manual
    * Reset ... diabled
    * IRQ3 and IRQ4 = PCI/ISA PNP
    * From IRQ5 to 10= Legacy ISA
    * IRQ11 PCI/ISA PNP
    * From IRQ12 to IRQ15 LEGACY ISA
    * DMA0,1 and 3= PCI/ISA PNP
    * DMA5 and DMA6 Legacy...
    * DMA7 PCI/ISA PNP
    * Pci Irq... Level
    * assisgn... disabled
    * PCI SLOT1 and 2 = Auto
    Integrated Peripherals
    * Onboard primary... disabled
    * Onboard Secondary diabled
    * IDE pref... enabled
    * IDE HDD... enabled
    * Onboard FCC.. disabled
    * Onboard UART 1 = 3E8/IRQ4
    * Onboard UART 2 = 2E8/IRQ3
    * Onboard Uart2 mode: standard
    * onboard parall... disabled
    There is a similar thread but without solution
    https://www.cnczone.com/forums/cinci...oard-bios.html
    Is it possible to have the binary file to flash it?
    Many Thanks!
    Dec 2006
    585
    Re: Arrow 750 - Alarm 40-33 Output/Fuse Failure in APC Rack 0
    When you remove the battery on the RTC board you will loose the BIOS. You will need to re-flash the BIOS or send it to FIVES machine company for a re-flash 800-934-0735 it is about $500.00
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Mar 2011
    465
    Not sure if this is related to the other post about the same alarm the same day this one was started, but if not...you may want to review the other threads.
    There are other causes for the alarm you mentioned, but if it started immediately after changing the battery, it is likely the BIOS needs to be reflashed. As Meckardt mentioned, you can send it to Cincinnati but there are other options as well. Siemens (which currently owns the Acramatic product line) also can do this, and I have been testing/reflashing boards for people on these forums for years (send me a PM if you are interested).
    Regarding your procedure you posted, that does not appear to be anything that was released by Siemens or Cincinnati, and is likely something that was typed up by an end user as they were attempting to get their machine working. Unfortunately, many of these things being posted do not work on all machines and simply cause headaches for all the people that try them unsuccessfully. This is why I will only respond with any machine specific settings directly (i.e. via PM) as posting something for one machine (even if it is correct for that machine) seems to cause issues for a number of other people that read the forum.
    Mar 2008
    288
    Maver1k and Meckardt55 both have posts to help with the Output Fuse Failure on APC Rack 0
    I have additional information attached:
    _A2100_AL40-33_Output Fuse Failure in APC Rack-0.pdf
    _50-pin_IDC Ribbon_Male-Receptacle-Keyed_Pinouts_A2100_CMHD.pdf
  1. Arrow Siemens "alarm 40-33 output/fuse failure on APC rack 0"
    By Serwis-Online in forum Cincinnati CNC
    Last Post: 07-05-2021, 11:47 PM
  2. APC Rack 5 Communication Failure
    By coop31 in forum Cincinnati CNC
    Last Post: 05-10-2018, 08:19 PM
  3. ARROW 750 THERMAL INPUT FAILURE/ALARM 39-120
    By wileycoyote in forum Cincinnati CNC
    Last Post: 04-03-2018, 10:22 PM
  4. Replies: 6
    Last Post: 01-02-2014, 08:13 AM
  5. APC Rack 1 Communication Failure
    Last Post: 10-12-2013, 01:56 PM
