587,369 active members*
3,394 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > APC Rack 5 Communication Failure
    Oct 2011
    205
    Keep getting this error on my Arrow 2 1250C
    Any ideas on how to solve this issue?
    Dec 2006
    585
    Re: APC Rack 5 Communication Failure
    You had the same problem in 2013 with rack 1 and you said that the switch on the module was in the wrong place, see the above (need help ). You may have a bad switch or a bad module. Try switching modules and see if the error stays with that module - don't forget to change the switches on both modules.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2011
    205
    Problem is I don't know what the module is and which one is rack 5.
  1. APC Rack 1 Communication Failure
    By coop31 in forum Cincinnati CNC
    Last Post: 10-12-2013, 01:56 PM
  2. Intermitted communication failure - Mach 3 - Redcam stepper cnc
    By ontariocnc in forum Mach Software (ArtSoft software)
    Last Post: 04-20-2013, 01:16 PM
  3. Helical Rack - would you prefer it to spur rack?
    By Diane-MooreGear in forum Linear and Rotary Motion
    Last Post: 10-01-2012, 08:02 PM
  4. Cat 40 Tool Holder Rack - Haas, Rack, or Benchtop
    By mecheng10 in forum News Announcements
    Last Post: 09-17-2011, 02:52 PM
  5. rack and rack & pinion with off the self planetary gearbox
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 12-06-2009, 03:54 PM
