587,453 active members*
4,228 visitors online*
Results 1 to 11 of 11
    Oct 2006
    100
    Fanuc Engineering Panel
    Any have info on a Fanuc Engineering Panel. What control is it used on ?
    24220
    I for one, am not sure what you are refering to?
    Al.
    Oct 2006
    100
    I believe its used for troubleshooting ? Looking for a manual some type of information.
    What do you mean
    Feb 2007
    38
    The only time I've ever had my hands on a FANUC engineering panel is on the model 200B control. Most are found on old amada punch presses. I believe they are the only way to change parameters on this particular control.
    Oct 2006
    100
    This panel has the function of stopping the control on the plc side. For troubleshooting. Write or read an address. This unit has a p/n A02B-0046-C902, maybe someone who work for Fanuc may have seen this unit. It also has P.C.B. A20B-0046-0900.
    24220
    I usually use the large Fanuc port computer to program PMC ladder and eeproms.
    Not sure wether this is the same unit?
    Al.
    Oct 2006
    100
    A System P Model G Mate, Do You Have a Manual 10/11 (FS3/FS6 Interface) Connection Manual GFZ-54813E-2, in PDF ? I will post a picture of the panel. Last night I sent a request to Fanuc Japan lets see if they answer ?
    24220
    Unfortunatly my PDF manuals start at 0 and 15, I only have in hard copy.
    Al.
    Jul 2007
    5
    i have one of these but no manual think its for a fanuc 6 control has a card that plugs into the master board for fault finding would like a manual if any on has one thanks
    Sep 2005
    767
    Lots of Fanuc controls can be fitted with engineering panels, but they're typically only used in a shop that's set up to repair circuit boards.
    The old 200 controls had a built-in engineering panel that was used to load the exec tape, change parameters, perform diagnostics, etc. Newer Fanuc models just have a plug somewhere that would let you plug in an engineering panel for service work. Personally, I've never seen one for the later models (like the Fanuc 6) but I do know that they exist. There's a plug for it, and there's an "ENPANE" selection on the ILD display to enable the panel.
    Basically, an engineering panel is a bunch of switches that lets you manually control the address buss and see the status of the the data buss. You can halt the microprocessor, or manually put any data into any memory address, etc. It's really only useful for messing around with the microprocessor at the lowest level, which is why we don't see them anymore.
    The programming gizmos for the PLCs are not the same as an engineering panel.
  1. WE-SIM by Whittlock Engineering
    By millman52 in forum Waterjet General Topics
    Last Post: 02-09-2012, 10:40 PM
  2. Reverse engineering
    By quadbob in forum PTC Pro/Manufacture
    Last Post: 04-27-2007, 12:54 PM
  3. British Engineering at it's best!
    By ImanCarrot in forum CNC Machine Related Electronics
    Last Post: 09-09-2006, 09:15 AM
  4. Fanuc 10m Panel controls not multiplexing
    By the professor in forum Fanuc
    Last Post: 01-20-2006, 05:23 AM
  5. engineering basics
    By inthedark in forum Community Club House
    Last Post: 03-27-2004, 10:21 PM
