586,655 active members*
3,205 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Broaching unit for cnc lathe
Results 1 to 9 of 9
    Oct 2016
    106
    Hi guys.
    I'd like to built my own broaching unit but I can't figure it out how this unit on retract move "drops" a small amount to avoid rubing.
    Any ideas? Drawings?
    Sent from my D5803 using Tapatalk
    Nov 2005
    222
    Re: Broaching unit for cnc lathe
    I think you will find what you are looking for here
    James on the Clough42 channel did a series where be builds a spindle lock, broaching bit, and writes code to do the broaching. I've built all the hardware for my mill but haven't tried it yet.
    Oct 2016
    106
    Hi, not exactly.
    I have done similar slotting already.
    But I'd like to speed it up by using broaching unit like Benz LinA or other manufacturers. They are pricey. $$$$
    Jun 2015
    4155
    hy, check attached / does it ring a bell ? i can help you with more specifics, like a simple sketch, toolholder organs dimensioning, talking about your desired approach, crafting tips, whatever you wish / kindly
    ps : drop amount has to be > turret radial feed among 1/2 M spindle turns multiplied by at least 20%, so to avoid friction even during high feeds; do the math this is why in that video, at 0:55, is said that max feed is 0.15mm/stroke, regardless of rpm value
    ps2 : x+ M spindle trigonometic, x- M spindle clockwise ... or viceversa
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Oct 2016
    106
    Hi. Can you explain it, I don't get it.
    Jun 2015
    4155
    this is for the "drop" behaviour; imagine such a cam, with the profile from the image from my previous post; the axis of this cam is coaxial with the M spindle
    Cylindrical Cam - YouTube
    Oct 2016
    106
    Do you know if the reciprocating action is made by conrod? have you seen one stripped? Have pictures maybe? Or could you sketch internal bits.
    Watched that cam video but still don't know how that works.
    Jun 2015
    4155
    hy what do you mean by "reciprocating" ? what is a conrod ?
    no, but i have watched a few videos with different types of constructions
    pls check attached : is a rough "kinematic chain"
    it will take me a while, in order to draw a functional type / kindly
    Jun 2015
    4155
    yes, z movement is done by a mechanism similar to a conrod
  1. Broaching on a CNC lathe
    By jsimon in forum G-Code Programing
    Last Post: 05-27-2015, 12:47 AM
  2. Rotary broaching on turret lathe
    By Stimey in forum MetalWork Discussion
    Last Post: 10-08-2012, 02:20 PM
  3. Broaching Job, Broaching head
    By unlock in forum Tormach Personal CNC Mill
    Last Post: 05-15-2010, 11:30 PM
  4. Broaching screwdriver slots on lathe
    By laka in forum MetalWork Discussion
    Last Post: 08-15-2008, 08:53 PM
  5. Keyway broaching on Lathe (need Y axis?)
    By pmurdock in forum MetalWork Discussion
    Last Post: 12-29-2007, 04:20 PM
