We are going to try and broach(shape) a keyway in a tapered bore on a CNC lathe with Fanuc 21i-TB controls and I need some help with the subprogram. The keyway is .3125 wide x .158 deep x 1.250 long with a 3.58° taper. The bore size is Ø2.2538 at the start and Ø2.4115 at the end. We are cutting cast iron. Here is what I have so far.
O4314 (KEYWAY)
( 4314 .3125 X .158 DEPP KEYWAY )
( 02/18/15 JES )
( KEYWAY CUTTER )
G99G20G0G54G40
G53X0.Z-18.0
M05
G54
G0T0101
G28H0.
G0X2.25382Z1.0C0.0
M68
M98P0002
G0G54Z1.0X#502
WHILE[#503LT#500]DO1
G0X#503M8
G1G98Z-1.3F250.0
G0X#502
G0Z1.0
#503=#503+#501
END1
G53X0Z-5.0
M01
O0002
(SUB FOR MACRO VARIBLE)
#500=2.5881(KEYWAY DEPTH)
#501=.001(DEPTH OF CUT)
#502=2.25(BORE SIZE)
#503=2.2538(START REFERENCE POINT)
M99
M30
Where do I put in the tapered information in the sub program?
Any help would be much appreciated.
