587,173 active members*
3,875 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Keyway broaching on Lathe (need Y axis?)
Results 1 to 4 of 4
    Mar 2006
    103
    I've tried doing all the reading I could on the best way to create an internal keyway inside a bore. I've found the PH Horn broaches that seem to be what I'm looking for. they suggest mounting them in the turret. I have a Haas SL-30 with live tooling (C-axis) on its way and I'm not quite sure whether this CNC lathe is capable of using these broaches as there is some confusion in my mind about what I will need a Y-axis on my lathe or not (which I don't think it has).
    any thoughts about keywy broaching on a lathe?
    cheers!
    Paul
    4826
    It should be possible without a Y axis, as I used to do the odd one on an ordinary manual lathe. What you'd need is the flexibility to orient the tool so that the insert axis is parallel with the X (cross slide) and then you can increment the cuts in X.
    Interesting find, BTW. I didn't know anybody made tools specifically for this
    Jul 2005
    12177
    This has been discussed previously; do a search using 'broaching lathe' and you will get several threads/posts.
    Mar 2006
    103
    Quote Originally Posted by Geof View Post
    Yes it has been discussed and that's how I found out about the PH Horn parts , but I didn't see anything about a Y-axis.. However the other question about how to orient the face of the tool on the X-axis. If you don't orient it just right the flat of the keyway will be all messed up.
    cheers,
    Paul
  1. mazak integrex broaching
    By precisiontork in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-27-2008, 01:57 PM
  2. Keyway or not to keyway... That is the question
    By jessbussert in forum Stepper Motors / Drives
    Last Post: 12-16-2007, 02:14 PM
  3. Broaching advice
    By Al_The_Man in forum MetalWork Discussion
    Last Post: 12-19-2006, 12:03 PM
  4. Automating the Broaching process
    By Donald in forum Mechanical Calculations/Engineering Design
    Last Post: 10-20-2006, 10:09 PM
  5. Broaching without a broach or press?
    By Chris D in forum MetalWork Discussion
    Last Post: 09-23-2005, 08:47 AM
