587,691 active members*
3,656 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
Page 1 of 7 123
Results 1 to 20 of 128
    Nov 2007
    361
    Hello to all ,
    I have a 3040-t cnc router from ebay and I am trying to get the spindle to come on using the program rather than using the spindle on switch and the speed pot knob also wanted to make the spindle shut off when the e-stop button is pressed . Right now when I push the e-stop button the spindle is the only thing that does not stop . I have searched youtube and I have found a few videos doing this but it was done a different type of controller box .
    This is the youtube video I was talking about it was posted by a man named Charles Sarsfield the only thing is this is a different type of box than the one I have
    https://youtu.be/OeBqSI8oevA
    The box I have is called mini cnc controller it does not have usb port on the back
    Mar 2007
    2083
    Re: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
    Hi Michael82
    For some reason you have private messages disabled
    Can you post detailed photos of the inside of the control box ?
    When I'll know what spindle speed control and breakout board you have
    I can work out what wiring you need to switch the spindle on & off
    John
    Nov 2007
    361
    Quote Originally Posted by john-100 View Post
    Hi Michael82
    John
    Hey john I checked my settings but cant see y I dont get PM's any way here are the pics from my box
    Nov 2007
    361
    Quote Originally Posted by Michael82 View Post
    This is the bob
    Nov 2007
    361
    This is the bob
    More pics of the power supply and spindle controller
    1236
    Do you have a reason to believe the spindle can actually be started by some means other than the switch?I might well be wrong,but can't see how a spindle with a switch can be started with the switch in the off position as the circuit will be broken and if the switch is in the on position it will be turning.I acknowledge that there could be relay on a parallel connection,but do you think there will be such a thing on a fairly basic machine?
    Nov 2007
    361
    watch the video that I posted at the bottom of this thread the guy in that video did it .. the switch comes from the unused relay switch on the driver board
    1236
    When I read the part where you posted "This is the youtube video I was talking about it was posted by a man named Charles Sarsfield the only thing is this is a different type of box than the one I have " it seemed likely that the difference in the type of box might be more than skin deep. If you have carried out the change and it hasn't worked,that would tend to support my belief.The obvious next step is to apply a multimeter to the output from the controller to the spindle to see if a voltage is being sent.
    Nov 2007
    361
    Quote Originally Posted by routalot View Post
    I should have explained myself a bit more sorry for that , rather than assuming that this could be done I should have asked , I have not carried out any changes yet and that is why Im here asking what it would take to make this happen ..... but knowing the difference between the box shown in the video and the box I have... made me asssume that this could be done even if I have to buy the same hardware as shown in the video.
    Mar 2007
    2083
    going by the limited view in your photos
    its going to take more details to reverse engineer your control box
    the control in the video is easy in conparison as it has the spare relay on the combined BOB and 3 axis driver board
    and labelled terminals on the PWM spindle speed control
    Attachment 431216
    in your control box
    you have a very simple BOB
    and 3 individual stepper drivers
    Attachment 431218
    your spindle speed contol looks like a modified power supply with a remote potentiometer
    Attachment 431220
    if its as I expect
    you may be able to connect an unused signal from the BOB to a relay with a built in current amplifier
    the relay then switching the mains supply to the spindle control
    John
    Nov 2007
    361
    Attachment 431216
    in your control box
    Attachment 431218
    Attachment 431220
    if its as I expect
    John
    so should I just redo the whole box??? make it alot like the video change the single stepper drivers to a 3 axis stepper board and change out the spindle driver I will take some more pictures of the sp[indle box open to get a better view of what is inside . Im at work now so around 4:30 central time I will post more pictures.... Thanks John for even looking at this for me as others just want to say it cant be done
    Mar 2007
    2083
    this is the first relay I found that may enable your BOB to switch the mains supply to your spindle
Name:	IACS 1 Channel 25A 30A 240V Relay Board SPDT Arduino Raspberry Pi 1XHCEL Optical.jpg
    https://www.ebay.co.uk/itm/IACS-1-Ch....c100752.m1982
    John
    Nov 2007
    361
    John
    ok where would this go to the bob to the spindle power?
    Nov 2007
    361
    What should be the supply voltage ? it ask on ebay when buying it 5v,9v,12v,24v
    Mar 2007
    2083
    After looking through your photos
    If the HN25-150-24 powers your stepper drivers , I would use the 24V version of the relay board so the stepper driver power supply can power the relay coil
    I will look for the circuit diagram of your BOB I have to find the connections that need to be connected to the relay board
    once I have double checked the relay board I will post the wiring diagram to connect the BOB , relay board and spindle speed control
    John
    Nov 2007
    361
    John
    OK and when I get to the house in about 1 hour I will post more pics of the spindle controller
    Nov 2007
    361
    John
    More pics to follow ....the black red and blue wires go to the speed pot knob the red and black wire to the right of those 3 wires go to the ac/24v on the bob , the 3rd wire from the left goes to the box labeled hn25-150_24 and the last red wire goes to the on /off switch for the spindle on the front of the box
    Mar 2007
    2083
    I have found this data sheet for the relay board
    Attachment 431258
    and a schematic for the BOB that needs checking
    Attachment 431260
    I have a couple of questions
    (1 how many axis does your machine have ?
    if you are only using 3 axis I would be inclined to connect the 4th axis to the relay board
    ( 2 do you have a multi meter to check the motor connector on the BOB ?
    Attachment 431262
    John
    Nov 2007
    361
    Here are pictures of the hn25-150-24
    Nov 2007
    361
    Attachment 431258
    Attachment 431260
    Attachment 431262
    John
    It is a 3 axis machine ....and yes I do have a multimeter...what do I check
Page 1 of 7 123
  1. 8 spindle rotary Cnc router making craket bat
    By omnisales6 in forum Videos
    Last Post: 06-29-2016, 04:02 AM
  2. Replies: 3
    Last Post: 12-20-2012, 07:09 PM
  3. Replies: 9
    Last Post: 07-05-2012, 08:57 AM
  4. Router Won't Turn On At Beginning of Program
    By notselrach in forum DNC Problems and Solutions
    Last Post: 02-06-2009, 10:08 PM
  5. G-Code to turn on and off router, non-spindle
    By Sam A in forum G-Code Programing
    Last Post: 10-25-2008, 02:02 AM
