587,794 active members*
3,197 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
Page 3 of 7 12345
Results 41 to 60 of 128
  1. #41
    Nov 2007
    361
    Re: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
    So looking at what came with the mpg and what is on the link posted the difference is the pin numbers I just went down starting at 1 with 5v-red
    2 with 0v-black...and so on ...so the pin numbers are not right does this mean i have to rearrange the wires to what the pin numbers are on the website???
  2. #42
    Mar 2007
    2083
    It depends
    Are you going to connect the MPG directly to the printerport or use an interface like the C22 board ?
    using a direct connection to the 2nd printerport
    A 5V power supply needs connecting to the red +5V wire and encoder 0V / printerport common / GND
    the incremental encoder A&B outputs and axis select and feed rate switches connections can go to any printerport input
    as long as you assign the correct function in pins & ports
    on the 2nd printerport
    pins 2 to 9 are inputs as well as pins 10 to 13 & 15 giving you 13 inputs
    from what I can see
    this Chinese digram
    Attachment 432680
    agrees with this
    Attachment 432682
    the green/black LED + wire can go to the +5V
    and white /black LED - wire can go to the -5V / GND
    you could use a USB cable to taket the 5V supply from the PC
    +5V going to the red wire
    -5V going to the black ground wire and the switch commons plus printerport Ground (pins 18 to 25)
    ( see table on page 6 of the C22 manual )
    https://www.cnc4pc.com/pub/media/pro...ser_manual.pdf
    Attachment 432684
    John
    PS
    just spotted on page 5 of the C22 manual a ref to a brain file
  3. #43
    Nov 2007
    361
    Quote Originally Posted by john-100 View Post
    It depends
    from what I can see
    this Chinese digram
    Attachment 432680
    agrees with this
    Attachment 432682
    Attachment 432684
    John
    PS
    Does item number = pin number on a db25 on the 2nd picture
  4. #44
    Mar 2007
    2083
    "Does item number = pin number on a db25 on the 2nd picture"
    that depends on if your using the C22 board
    if you look at the table in the 3rd picture
    the pins on the pendant connector connect to different pins on the PC connector
    for example
    on the pendant pins 1 & 2 go to a 5V supply
    on the PC connector pin 1 is a PC printerport output controlling the LED
    and pin 2 is the input from the incremental encoder channel A
    Wiring the MPG directly to a DB25 connector to connect to the PC printerport
    you will need to bring the MPG red & black wires out of the DB25 to a 2 pole connector to go to a 5V supply -
    which could be a USB cable to take power from the PC
    John
  5. #45
    Nov 2007
    361
    for example
    John
    Ok I am using a 2nd printer port added to my pc . So I would then need to reroute my pin 1 and 2 ? Damn it so how does that work john ??
  6. #46
    Nov 2007
    361
    Quote Originally Posted by Michael82 View Post
    Sorry if I seem helpless I have never done anything like this before I am use to plugging the plug in the socket and turning the machine on thanks again in advance for explaining all this. Where would I get the 5v from on the desktop ?? USB... but how I need a breakout board for this too ??
  7. #47
    Mar 2007
    2083
    my initial thoughts on how the C22 board works resulted in this
    Attachment 432714
    note - I have not found any circuit details on line
    adapting the diagram to hard wire the MPG
    resulted in this
    Attachment 432716
    John
    PS
    second version of hard wired MPG with LED connected to +5V
    so printerport pin 1 grounds the LED cathode (negative terminal)
    the printerport pin1 may not be able to source very much current to light the LED indicator
    Attachment 432718
  8. #48
    Nov 2007
    361
    Attachment 432714
    resulted in this
    Attachment 432716
    John
    PS
    Attachment 432718
    So would it be better to buy a c22 board
  9. #49
    Mar 2007
    2083
    the C22 board has the advantage of having the 2 buffer IC's
    and terminals making it easier to connect the 5V supply to the MPG
    John
    PS
    if you take 5V from a USB socket
    Attachment 432722
Name:	USB pinout.jpg
  10. #50
    Nov 2007
    361
    John
    PS
    Attachment 432722
    John after doing as much research I can stand I have not found anyone that has wired their mpg directly to the printer port without a c22 board . I dont have a c22 board so I have to try and do this without it ....or buy one .... so could I use an outside 5v power source for the 5v and the 0v and use the rest of the pins as shown in the pinout ??
  11. #51
    Nov 2007
    361
    Hey john what about getting the 5 volts from the PC's power supplys disk driver cable would that work??
  12. #52
    Mar 2007
    2083
    a USB cable as in post 49 is an easy solution that enables you to just plug into an existing external socket
    25pin D-type plug and USB plug to MPG cable
    if the USB cable joint is hidden inside the D-type shell
    the USB cable can be held under the clamp with the MPG cable
    ( use heatshrink sleeving to insulate the joint )
    the LED indicator can be wired to the 5V supply
Name:	mpg wiring to d type & usb.jpg
    yes you can connect the MPG to a PC power supply black 0V wire and red +5V wire ( not the yellow + 12V wire !!!! )
    you can either use a 4 pin molex connector or 15 pin SATA connector as used on internal disk drives and then thread the cable through the PC case
Name:	MPG   pulse generator + 4 pin molex.jpg
    John
  13. #53
    Nov 2007
    361
    John
    I like that setup you have posted rather than the 1 I suggested and I have that exact db25 connection too!
  14. #54
    Nov 2007
    361
    After trying every combo possible I still can not get this dang thing to work so I ordered a c22 board from cnc4pc it should be here in a few days ..if anyone out there has successfully wired there manual pulse generator direct to the LPT2 without using a c22 board please let me know how you did it
  15. #55
    Mar 2007
    2083
    I would disable the onboard printerport and set up the printerport adaptor as the "first" port at 278 hex
    then set it up in ports and pins with the setting you used for the onboard port
    with the correct card address you should be able to control the stepper motors as before
    proving the printer port adaptor is working
    if the adaptor works we need to look closer at how you set up the adaptor for the manual pulse generator
    if I remember correctly the onboard printer port is at 378 hex and the adaptor printer port is at 278 hex
    John
  16. #56
    Nov 2007
    361
    john , the 2nd pci printer port has the address of e000 so that is what I put in the 2nd port no mach 3 and I checked the box use pin2-9 as well so you are saying disable the 378 #1 port and make that 2nd port ( E000) the only port enabled?
  17. #57
    Mar 2007
    2083
    yes
    With the onboard port disabled
    and mach3's only port set to E000 (if thats what the motherboard & windows 7 sees it as )
    You should be able to set the port up to replace the onboard port with the same pins and ports setting copied from the onboard port
    If the adaptor card is working
    you should be able to jog the stepper motors as before
    depending on the test result
    you will know if the problem is with the printerport adaptor or the MPG
    in Mach3 the first port gives you 5 inputs and 12 outputs
    The second port gives you the option of setting pins 2 to 9 either as 8 inputs or 8 outputs
    To use your MPG , pins 2 to 9 needs to be set as inputs
    giving you 4 outputs and 13 inputs
    As the axis and step select switches grounds the selected input
    the inputs need to be set to ACTIVE LOW
    set to active high will result in mach3 seeing too many active inputs - not sure how mach3 will respond
    John
  18. #58
    Nov 2007
    361
    ok I will try that later this afternoon and I will post the findings
  19. #59
    Nov 2007
    361
    yes
    John
    John the weirdest thing happened I disabled port 1 and used the 2nd port like it was the only port nothing happened but when I went back to the way it was now the selector switches work in the port 1 pins current state on the bottom row but still no movement from the wheel . So now I know the selector switches work so where should I go from here
    Ps
    Port 1 is back to the main port and the 2nd port is for the mpg
  20. #60
    Mar 2007
    2083
    I've had odd results with windows either not seeing new hardware or loading drivers correctly first time the PC boots
    Do you have a multimeter to check the 5V supply to the rotory encoder ?
    once you confirm the 5V supply is correct
    measure the voltage between the common 0V and A output
    depending on its position when stopped you will either have 0V or +5V
    while your rotating the knob the output will switch between 0 & 5V (50% of the time at 0V and 50% at 5V)
    ( see the Quadrature outputs here :-
    https://en.wikipedia.org/wiki/Incremental_encoder )
    your meter will read the average 2.5V
    you should see the same measuring between 0V and the B output
    John
Page 3 of 7 12345
  1. 8 spindle rotary Cnc router making craket bat
    By omnisales6 in forum Videos
    Last Post: 06-29-2016, 04:02 AM
  2. Replies: 3
    Last Post: 12-20-2012, 07:09 PM
  3. Replies: 9
    Last Post: 07-05-2012, 08:57 AM
  4. Router Won't Turn On At Beginning of Program
    By notselrach in forum DNC Problems and Solutions
    Last Post: 02-06-2009, 10:08 PM
  5. G-Code to turn on and off router, non-spindle
    By Sam A in forum G-Code Programing
    Last Post: 10-25-2008, 02:02 AM
