587,935 active members*
4,396 visitors online*
    Feb 2011
    212
    strange pulsating noise from x axis motor
    I have been hearing this annoying noise coming from the x axis motor. It's not loud at all but can only hear it when the mill is sitting there at idle. What could be the cause of this ?
    The drive wires are separated from all the other wires to prevent unwanted noise .
    794
    Re: strange pulsating noise from x axis motor
    Hello,
    My IH mill has done this in the past. What it turned out being is the gecko was adjusted too tight. Usually the gain is needing a little counter clockwise adj. till quiet. The Damp may need same. Don't be afraid of it. Turn off all noises, and listen close to motors. You will quickly find out what I mean once you try it. This is the only way to adjust without an oscilloscope.
    simple cw noisy and ccw quiet
    Don
    IH v-3 early model owner
    Feb 2011
    212
    Thanks .
    794
    Does silence mean success ? I am sure some here would be interested !
    Don
  1. Strange noise with laser engraver
    By ddestroyer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-23-2014, 11:27 AM
  2. G0704 Motor Pulsating All Speeds...
    By Contract_Pilot in forum Benchtop Machines
    Last Post: 09-01-2014, 12:00 AM
  3. New Tormach with strange Zaxis noise
    By hall6ppc in forum Tormach Personal CNC Mill
    Last Post: 08-28-2011, 06:25 PM
  4. Z-axis motor noise
    By RP Designs in forum Centroid CNC Control Products
    Last Post: 11-08-2009, 04:09 AM
  5. loosing steps & strange noise
    By BobF in forum Mach Software (ArtSoft software)
    Last Post: 12-02-2007, 05:01 PM
