Re: Contactor, Cooked Coil
I suspect the way the coil works is that the contacts are closed in order for higher current to pick the relay armature up, once a DC relay or solenoid armature has shifted it requires much less energy to keep it closed, if this is correct and the relay picks up but the contacts do not open for some reason, could cause burn out of the coil?
Al.
Albert E.
