I have 2 AEG LS 37 contactors that I'm using to power up 2 servo drives. The contactors I'm using are surplus, one of which cooked a coil on my 1st power up. Initial quick testing for latching worked fine.I'm not sure what went wrong.
These are 24v DC coil, the power supply I'm using is outputting 23.9V DC which I can adjust if need be.
These particular contactors use an external HS17 contact block that the coil pigtails tie into.Without this block, the coil does not energize. This contact is NC and opens when the contactor closes.
I think the plastic fingers on the external contact were not fully grabbing the body of the main contact mechanism, perhaps leaving the circuit closed too long when retracted causing the coil to cook? Is that a possibility?
I'm not fully understanding why these contactors came with this type of external contact. I believe this was called the late brake version?
Just to clarify, one of the contactors operates fine both were wired the same. I'm getting a replacement and want to make sure I wire this correctly in case I got this wrong.
OT
