587,517 active members*
3,150 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > What's that gizmo across the contactor coil?
Results 1 to 2 of 2
    Apr 2010
    3
    Hi All,
    On a Bridgeport Series 1, attempting to turn the spindle on blows a fuse in the 120v circuit (Fu4, 6A). So I'm thinking I have a problem in the contactor or the switch, especially because the previous owner had problems with the contactor (he priced a replacement, but didn't replace it). Advice is welcome.
    In particular, what is the device that is wired across the coil of each of those contactors, and how do you test it? The schematic uses a symbol I can't identify, looks like a capacitor connected to something represented by a rectangle!
    Thanks,
    Joe
    Dec 2003
    24220
    The two likely hoods are Varistor or (R/C) resistor/capacitor snubber, my guess would be a R/C type, this is to suppress any back EMF spike.
    If R/C type a test with a meter should show open.
    The varistor should not be discoloured and show high resistance.
    Post #2, http://www.cnczone.com/forums/genera...ion_error.html
    Al.
    Albert E.
  1. Rewinding a coil
    By Shanghyd in forum CNC Machine Related Electronics
    Last Post: 10-22-2010, 12:49 PM
  2. Need Help with Magnetic reversible Contactor
    By Chris64 in forum CNC Machine Related Electronics
    Last Post: 12-23-2007, 09:54 PM
  3. Coil Winder
    By itsme in forum I.C. Engines
    Last Post: 08-25-2006, 07:12 PM
  4. testing a coil
    By Fabric8r in forum CNC Machine Related Electronics
    Last Post: 06-09-2006, 02:30 PM
  5. Contactor help ????
    Last Post: 05-26-2006, 11:27 PM
