587,517 active members*
3,418 visitors online*
IndustryArena Forum > CAM Software > CamBam > No drill points detected.....WTF?
Results 1 to 7 of 7
    Sep 2011
    474
    Im making part that has holes drilled in it somewhat randomly. Ive some this before so must have forgotten how it works. I get only error messeges telling me "no drill points detected". This is after assigning all the holes with a drilling operation. Has anyone else seen this? Im stuck.
    Aug 2005
    29
    Re: No drill points detected.....WTF?
    I know that if I have a tool which is larger than a hole I need to drill in another CAM package the toolpath won't include those smaller holes. Could it be something along those lines?
    Sep 2011
    474
    Quote Originally Posted by ckovacs View Post
    I'll double check and get back with you. Thanks for the tip.
    Sep 2011
    474
    Quote Originally Posted by SwampDonkey View Post
    Yeah that wasnt the issue. The mill drilled a few holes, gave me an M6 command and stopped even though there were no tool changes at that point. In fact it begins everything with m M6 command.
    Sep 2011
    474
    No it wont eben run the program because of the "no drill points detected. And gurus in the house?
    Nov 2008
    412
    It's hard to tell what went wrong without seeing the Cambam file.
    Forget about global warming...Visualize using your turn signal!
    Aug 2005
    29
    Are the holes different sizes? If they are then a tool change would be appropriate. If the bit is smaller than all the holes you might try a milling operation in stead of a drilling one. No expert here but just stuff I've run into.
  1. picking drill points in Mastercam 4
    By greggv in forum Mastercam
    Last Post: 04-19-2013, 05:09 PM
  2. picking drill points in Mcam4
    Last Post: 04-11-2013, 05:19 AM
  3. Engraving drill points in CRS steel
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 12-14-2009, 05:02 AM
  4. Drill 5 axis - points and lines
    By jcnewbie in forum Mastercam
    Last Post: 10-18-2009, 09:24 PM
  5. Adding drill points to a rectangle
    By Joe Rodney in forum Mastercam
    Last Post: 10-19-2008, 09:35 PM
