586,920 active members*
2,537 visitors online*
Results 1 to 2 of 2
    Apr 2008
    20
    Mazak ST40N Gear selection
    We have a ST40N with a three speed gearbox.
    However whatever we program, big dia, small dia the machine always seems to select high gear.
    We can change gear in manual mode fine and change gear in mazatrol with an M code
    however as soon as it starts a machining unit high gear gets selected?
    Anyone help
    Cheers
    Andy
    Aug 2016
    2
    Re: Mazak ST40N Gear selection
    I realise this is extremely late reply but anyway for anyone else
    The gear range is selected in the TPC data.
    You can set for roughing and finishing
  1. Mazak ST40N ATC Alarms
    By Mert-G in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-28-2019, 11:29 AM
  2. Turning Gear Selection in post builder
    By bootdisc in forum UG NX
    Last Post: 01-24-2014, 03:56 PM
  3. Ballscrew and gear ratio selection for my new cnc
    By ba99297 in forum DIY CNC Router Table Machines
    Last Post: 09-20-2013, 11:12 PM
  4. MAZAK QT35N 3rd GEAR ONLY!!
    By beto81 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-15-2013, 06:33 PM
  5. Gear selection...my rapids are too rapid!
    By benjamint76 in forum DIY CNC Router Table Machines
    Last Post: 02-09-2012, 05:26 PM
