Hello,
We are having difficulty getting the post to auto select the right turning gear from the SMM (G96) speed given when creating the tool path.
We have 4 gears that require either an M41, M42, M43 or an M44 depending on the what the maximum revs is required.
M41=0-200revs, M42=0-500, M43=0-1500, M44=0-3000
How do I configure the post to auto choose which gear depending on the SMM given whilst considering the smallest diameter it will be cutting?
For example, if I choose 320 SMM and the smallest diameter to be cut is 150mm it will require to output an...
M43 (Gear 3)
M203 G96 S320 (SMM)
Can anyone help me please?
