Hello Everybody,
Machine: Mazak ST40N ATC
Control: Mazatrol CAM T-3
Question1:
After homing (first X then Z or first Z then X) the following alarm appears;
102 STORED STROKE LIMIT -X
What is the reason? Should I change a parameter related to soft limits?
Question2:
This machine has also a C Axis but it is not servo. There is a gear system that can rotate the chuck min 1°. It has no interpolation with other axes.
Now the machine shows;
257 C-AXIS OR SHIFT LS MALFUNCTION
And the led on "C-AXIS I/O" key blinks. Can you advise?
Question3:
Do you have a list that explains all the parameters one by one?
Thanks in advance.
Best Regards,
Mert
