587,534 active members*
3,512 visitors online*
    Jul 2012
    Need help with coding
    How do i read sensor voltage to microcontroller, PIC18F4520. Any codes i can use?
    Nov 2011
    You need to get MPLAB and a chip programmer. Write your assembly in the MPLAB and then download your hex file to the chip. You will have to write a code to read the voltage on the ADC pin of the chip. It is 10 bit resolution. Read about ADCON0, ADCON1, ANSEL, ADRESL, and ADRESH. If your voltage to read is over the Vss of the chip, you will have to use a voltage divider to scale the results down.
  1. Anyone know some advanced GPP coding?
    By SolidCam_ in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-25-2012, 04:58 PM
  2. Roller cam coding
    By greybeard in forum Coding
    Last Post: 10-23-2010, 06:28 PM
  3. Algorithm for G02 / G03 coding
    By jemmyell in forum Coding
    Last Post: 08-06-2009, 11:58 PM
  4. New to G-Coding
    By Larry Myers in forum G-Code Programing
    Last Post: 09-20-2007, 03:06 PM
  5. G2/G3 Coding
    By jrobson in forum G-Code Programing
    Last Post: 09-02-2006, 06:54 PM
