587,419 active members*
3,494 visitors online*
Thread: G2/G3 Coding
Page 1 of 2 12
Results 1 to 20 of 25
    Aug 2006
    89
    G2/G3 Coding
    Can someone point me to some documentation that properly explains G2/G3 coding on 5T/6T Fanuc controllers with tool nose radius compensation?
    Jan 2006
    4396
    This book will help you and it's not cheezy. It will explain things so you can understand.
    http://www.amazon.com/gp/product/013...e=UTF8&s=books
    It also goes over the tool tip selections for using TNRC (Tool Nose Radius Compensation)
    Example: is a Fanuc 10T
    O0086
    (TURBINE SPLINE 27SPL)
    (GM 200 TH200R4)
    (MATERIAL=4140)
    (PILOT=1.375D)
    (ID=.814D)
    (DRWNG=SPLINEA.CAD)
    (OP#1)
    (DATE 8/1/03 PGMR TJD)
    (DATE REV 1/27/04 TJD)
    (T1=CNMG432 VALINITE SV330 T3)
    (T3=DNMG431 SECO FF1 CM T3)
    (T5=DRILL 3/4 135SPT COB STUB)
    (T7=B-BAR 1/2 CCMT21.51F2 TP1000 T2)
    (SECO CARBOLOY)
    (JAWS=400 PRESS=20)
    (CYCLE TIME=MS)
    G0 G40 G97 G99 T0 M5
    G28 U0 W0 M9
    G50 S2000 M41
    M1
    N1(REMOVE SKIN/R-FACE/TURN)
    G28 U0 W0 T0
    T101 M8
    G96 S475 M4
    G0 G42 X3.99 Z.3
    G1 Z-1.3 F.01
    X4.05 F.015
    G0 G40 X4.1 Z.2
    G72 P10 Q15 W.005 D400 F.008
    N10 G0 G41 Z0
    N15 G1 X0 F.004
    G0 G40 X4.0 Z.1
    G71 P20 Q25 U.02 W.002 D850 F.01
    N20 G0 G42 X1.0
    G1 Z0 F.0025
    X1.325 F.003
    G3 X1.375 Z-.025 R.025 F.0025
    G1 Z-.75 F.004
    X2.75 F.0035
    X3.975 Z-.9141 F.0025
    G1 Z-1.08 F.004
    N25 X4.1 F.0035
    G0 G40 Z.1 M9
    G28 U0 W0
    G97
    T0
    M1
    N2(F-FACE/TURN/U-CUT)
    G28 U0 W0 T0
    T303 M8
    G96 S650 M4
    G0 G41 X1.5 Z0
    G1 X0 F.004
    G0 G40 X4.1 Z.1
    G70 P20 Q25
    G0 G40 Z.1
    (U-CUT)
    G1 X1.3755 Z-.725 F.05
    Z-.755 F.004
    G4 U1.0
    G1 Z-.75 F.006
    X2.8 F.003
    G0 G40 Z.1 M9
    G28 U0 W0 M5
    G97
    T0
    M1
    N3(DRILL)
    G28 U0 W0 T0
    T505 M8
    G97 S400 M3
    G0 X0 Z.25
    G1 Z-2.25 F.0072
    Z.05 F.2
    G0 G40 Z.1 M9
    G28 U0 W0
    G97
    T0
    M1
    N4(R-BORE )
    G28 U0 W0 T0
    T707 M8
    G96 S400 M3
    G0 G40 X.75 Z.1
    G71 P40 Q45 U-.02 W.002 D320 F.0075
    N40 G0 G41 X1.214
    G1 X.814 Z-.1 F.003
    Z-1.3 F.005
    N45 X.75
    G0 G40 Z.1 M9
    G28 U0 W0
    G97
    T0
    M1
    N5(F-BORE)
    G28 U0 W0 T0
    T707 M8
    G96 S550 M3
    G0 G40 X.75 Z.1
    G70 P40 Q45
    G0 G40 Z.1 M9
    G28 U0 W0
    G97
    T0
    M30
    If your Control sets tools with a G50 I'll post an example for that one as well.
    :cheers:
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Aug 2006
    89
    Hi
    Thank you!
    Yes our control sets with G50.
    Regards,
    Jonathan.
    Jan 2006
    4396
    Here is a simple example of a program with G50. Do you know how to set your tools with G50 yet? If not I'll post instructions too.
    O1154
    (IKEGAI FANUC 6T)
    (ANTI-BALLOONING PLATE)
    (DRWNG=ABPLC1.CAD)
    (MATERIAL=SAE 1018)
    (5.0D 1.075L)
    (OP1)
    (DATE 1/15/04 PGMR TJD)
    (DATE REV 1/15/04)
    (LAST RUN)
    (T1=CNMG432 VALENITE SV330 T3)
    (T2=DRILL 1.0D INDEX)
    (T4=B-BAR .5D CCMT21.51-F2 TP1000 T2)
    (T5=B-BAR 1.0 D .0312R T2)
    (JAWS=400 PRESS=18)
    (CYCLE TIME= MS)
    G0 G40 G97 G99 M5
    G28 U0 W0 M9
    G50 S2000 M39
    M1
    N1(R-FACE/TURN)
    G28 U0 W0
    T0100
    G50 X(RP) Z(RP) M8
    G96 S525 M3
    G0 X5.2 Z.2 T0101
    G72 P10 Q11 W.005 D400 F.008
    N10 G0 G41 Z0
    N15 G1 X0 F.004
    G0 G40 X5.2 Z.1
    G71 P20 Q25 U.02 W.005 D750 F.01
    N20 G0 G42 X4.765
    G1 X4.985 Z-.01 F.0025
    Z-.75 F.004
    N25 X5.2 F.0035
    G0 G40 Z.1 M9
    G0 X(RP) Z(RP) T0100
    G28 U0 W0
    G97
    M1
    N2(DRILL)
    G28 U0 W0
    T0200
    G50 X(RP) Z(RP) M8
    G97 S2400 M3
    G0 X0 Z.2 T0202
    G1 Z-1.125 F.0025
    Z.05 F.2
    G0 G40 Z.1 M9
    G50 X(RP) Z(RP) T0200
    G28 U0 W0
    G97
    M1
    N3(F-FACE/TURN)
    G28 U0 W0
    T0300
    G50 X(RP) Z(RP) M8
    G96 S650 M3
    G0 X5.2 Z.2 T0303
    G70 P10 Q15
    G0 G40 X5.2 Z.1
    G70 P20 Q25
    G0 G40 Z.1 M9
    G0 X(RP)Z(RP) T0300
    G28 U0 W0
    G97
    M1
    N4(R-BORE)
    G28 U0 W0
    T0400
    G50 X(RP) Z(RP) M8
    G96 S400 M3
    G0 X1.0 Z.1 T0404
    G71 P40 Q45 U.02 W.02 D320 F.0075
    N40 G0 G41 X4.6628
    G3 X1.975 Z-.3 R2.5 F.0035
    G1 X1.875 Z-.35 F.0025
    Z-.43 F.004
    X1.518 F.0035
    X1.483 Z-.455 F.0025
    Z-.9 F.004
    N45 X1.0 F.0035
    G0 G40 Z.1 M9
    G0 X(RP) Z(RP) T0400
    G28 U0 W0
    G97
    M1
    N5(F-BORE)
    G28 U0 W0
    T0500
    G50 X(RP)Z(RP) M8
    G96 S550 M3
    G0 X1.0 Z.1 T0505
    G70 P40 Q45
    G0 G40 Z.1 M9
    G0 X(RP)Z(RP) T0500
    G28 U0 W0
    G97
    M30
    Toby D.
    Schwarzwald
    Aug 2006
    89
    Hi there
    Yes I have no programming problems, simply that with G2/G3 I can't calculate I and K properly...
    Aug 2006
    89
    On the 6t it is usually okay, but on the 5t very difficult. In the past someone did the G2/G3 for me via mastercam or edgecam or something however this is no longer a option.
    Jan 2006
    4396
    You don't need I and K for that control. Use "R" letter address, it will work.
    Toby D.
    Schwarzwald
    Jan 2006
    4396
    Quote Originally Posted by jrobson
    I have some free time and could help you with this if you would like.
    Toby D.
    Schwarzwald
    Aug 2006
    89
    Hi
    On the 5T there is no R only I/K...
    If you can help I would really appreciate it as I have no idea how to calculate it properly...
    Jan 2006
    4396
    Ok that is an older control. I never use "I" and "K", but I'll figure it out. How does the machine read "I" and "K" Absolute or Incremental? This is very important to know when programming. What Machine Tool is It? Tsugami, Nokamora Tome, Ikegai, Mori Seiki, Hitachi Seiki, or Dainichi?
    Before I forget go to www.ncplot.com this will help you to view your programs before sending them to the Lathe. It also will help you to learn to hand code.
    Toby D.
    Schwarzwald
    Aug 2006
    89
    Hi
    Thanks I will look at the link, I and K are absolute, machines are Ikegai and Mori Seiki, Hitashi Seiki and Wasino are both 6t.
    Jan 2006
    4396
    Ok I will post a simple drawing and G-Code using "I" and "K"
    Toby D.
    Schwarzwald
    Aug 2006
    89
    Thanks!
    Jan 2006
    4396
    Simple Drawing and Program
    This should be what you need.
    O0000
    (IKEGAI FANUC 6T)
    G0 G40 G97 G99 M5
    G28 U0 W0 M9
    G50 S2000 M39
    M1
    N3(F-F/T)
    G28 U0 W0
    T0300
    G50 X(RP) Z(RP) M8
    G96 S650 M3
    G0 X4.2 Z.1 T0303
    G42G1X0.F.025
    G1Z0.F.006
    X0.5
    G3X1.Z-0.25I0.K-0.25
    G1Z-0.75
    G2X1.5Z-1.I0.25K0.
    G1X3.5
    X4.Z-1.25
    Z-4.
    X4.1F.025
    G40 G0 Z.1 M9
    G0 X(RP) Z(RP) T0300
    G28 U0 W0
    G97
    M1
    Sorry it took so long a Client called. Follow the program from X0 Z.1
    Toby D.
    Schwarzwald
    Jan 2006
    4396
    I just sent you my email address if you need additional help with this.
    :cheers:
    Toby D.
    Schwarzwald
    Aug 2006
    89
    Hi
    Yes that is logically correct the way I see it and the way I calculate it as well, however if you take that same drawing, run it through something like edgecam and compensate for the tool radi it looks completely different(ex:G3 X1.004 Z-0.291 I0.081 K-0.211) , what sometimes happens with a code like yours is that the circular bit isn't 100% smooth, it usually has a ridge, once the code is changed to the figures from the computer it is smooth.
    Jan 2006
    4396
    Hi
    What do you mean smooth? Are there flat spots at the largest points in the diameter. I recieved your email and Iges file. The arc segments are 90 degree and 180. I hope this works for you.
    :cheers:
    90 DEGREE ARC SEGMENTS
    NOTICE THE G3 HAS TW0 LINES OF
    G-CODE
    ****NOTE****
    TO USE TOOL NOSE RADIUS
    COMPENSATION YOU MUST CHANGE
    TOOL TIP REGISTER TO T8
    SET THE RADIUS "R" TO THE TOOL NOSE
    RADIUS YOU ARE USING EX. VNMG431 HAS
    A .0156 TNR R=.0156
    G3 IS MODAL UNTIL CHANGED
    N3(F-F/T VNMG431 SECO FF1 TIP 8)
    G28U0W0T0
    T303M8
    G96S650M3
    G50X(RP)Z(RP)
    G0X12.7Z2.54
    G42G1X2.54Z0.F.015
    Z-1.6829F.008
    G3X9.Z-6.I-1.27K-4.3171
    X2.54Z-10.3171I-4.5K0.
    G1Z-10.73
    X12.7F.015
    G0G40Z25.40M9
    G50X(RP)Z(RP)
    G28U0W0
    G97
    T0
    M1
    _____________________________
    180 DEGREE SEGMENT
    N3(F-F/T VNMG431 SECO FF1 T8)
    G28U0W0T0
    T303M8
    G96S650M3
    G50X(RP)Z(RP)
    G0X12.7Z2.54
    G42G1X2.54Z0.F.015
    Z-1.6829F.008
    G3Z-10.3171I-1.27K-4.3171
    G1Z-10.73
    X12.7
    G0G40Z25.4M9
    G50X(RP)Z(RP)
    G28U0W0
    G97
    T0
    M1
    Attached Files Attached Files
    Toby D.
    Schwarzwald
    Mar 2006
    1625
    what the ridges jrobson is refeering to, is the end point of the r value the tool is stopping for a milla-second before completing move (look a head) with I and J the move is a full motion-a full block of code
    Jan 2006
    4396
    Quote Originally Posted by lakeside
    Some Lathes do not accept a full 180 degree radius move, at least probibly not his. It's pretty old. The 1984 Ikegai Fanuc 6T might, but I never got a part with this type of geometry to try it. Here is the drawing Mike.
    Seems it won't post here. Sending to your email.
    Toby D.
    Schwarzwald
    Apr 2006
    26
    To count I and J (in turning applications K) you just need to calculate each axis movement,that's all... related to the quadrant and direction... I know how to calculate it but still have a problem with right signs definitions ...accordingly to the direction does anyone knows about it? thank you in advance...
Page 1 of 2 12
