587,058 active members*
4,050 visitors online*
    Sep 2008
    18
    Bosch CC220 I/O problems.
    We have recently had issues relating to sending programs,The main and latter subs arrive but the first sub does not show up at the control. This is a trumpf 200 punching machine. We are using WinDNC a trumpf product for sending but have also tried DNC precision with no success. Any Input would be greatly appreciated.
    Nov 2009
    6
    Check the communication settings. If no I/O error occurs then it's a problem in the program or the machine is trying to access a table that does not exist. In this case it sometimes prints an error. This is a sample of how we write the programs on a Lasecomb dieboard laser cutting machine. We don't write subs -- we just convert a 2d drawing and load it to the machine.
    Sample -- this will draw a rectangle, a circle and an arc:
    (DFS,P 11111 ,DRAWING1)
    N10P99999902
    N20G90G73
    N30F850
    N40M54
    N50G0X0Y0
    N60G0X260.387Y27.578
    N70M56
    N80M52
    N90G3X234.647Y155.358I-45.389J57.339
    N100M54
    N110G0X232.759Y117.126
    N120M52
    N130G3X232.759Y117.126I-1.789J-36.229
    N140M54
    N150G0X184.087Y171.905
    N160M52
    N170G1X0
    N180Y0
    N190X184.087
    N200Y171.905
    N210M54
    N220G0X0Y0
    N230P99999903
    N240M02
    If you want you can send the drawing file in dxf, cdr, cff etc and I will convert it to CC220 program.
  1. unlock code for BOSCH CNC CC220
    By JuanMatus in forum Controller & Computer Solutions
    Last Post: 03-19-2022, 06:25 PM
  2. Problem with BOSCH CC220!
    By laserino in forum MetalWork Discussion
    Last Post: 02-06-2011, 11:04 AM
  3. Bosch z15 1 240
    By timboss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-09-2008, 05:24 PM
