587,224 active members*
4,436 visitors online*
Page 1 of 2 12
Results 1 to 20 of 35
    Dec 2008
    3
    unlock code for BOSCH CNC CC220
    Does somebody knows the code for unlocking parameters memmory of BOSCH
    CNC C220. Also what means error mеssage NC-FEHLER 2665?
    Oct 2007
    1
    Try this:
    468 SAVE DATA
    355 Permanent protection ?
    377 EPROM I/O
    252 SERVICE
    438 DELETE ALL TABLES
    630 DELETE ALL MEMORY =>RELOAD
    339 SERVICE FUNCTION (PIC / PLC)
    340 EDIT PROGRAM (CLP)
    683 Variable Edit
    377 LIBRARY LOCK/UNLOCK
    Dec 2008
    3
    Smile Thank you
    Thank you very much. That is just what I need. You are great man.
    Oct 2004
    4
    HELP WITH BOSCH CC220
    Hi ,
    i have the same controller bosch cc220, please send me how to activate backup (error code 277).
    kris
    Dec 2008
    3
    Try this:
    468 SAVE DATA
    377 EPROM I/O
    252 SERVICE
    683 Variable Edit
    Nov 2008
    5
    m/c status bosch cc220
    I have the same control bosch cc220 do you know whats mean status 20 and status 19.
    In my manuals only I read "errors" and "troubleshooting" but status not.
    Do you have a list of status
    Jan 2011
    0
    Bosch cc220 problem
    Hi there,
    My name is Dimitar and we currently have a big problem with our cnc machine Rye MA1512 TPTC. We have damaged our 16 k RAM/ eprom memory and have ordered another one from the states. After changing it, the plc inhibit error is no longer( pls reffer to photos 3 and 4), but now we have got Machine status 1, Axis E.O.T. and low vacuum in U errors( photos 1 and 2). We know that there was nothing mechanically wrong with the CNC (Rye MA1512 TPTC), but still don't know what to do to get it up and running again. Non of the programs we see on the screen are present on the Ram/ Eprom...
    Please, find attached the photos of the screen showing the errors and the inside of the pc cupboard. On the latter one you will see on the furthest RH side card 4 no lights on. Actually they are not on, but flashing all the time- I think this might be another clue for someone who knows the machine.
    Looking forward to get your replies/ help!
    Thank you very much in advance!
    Feb 2012
    0
    Hi
    Need help!
    Have the same problem like DIMITAR. We have Balstfulland CNC 1000 with BOSCH CC300M controler with 4 axes.The batery 3,6V on MEM3 modul was empty and all data and files lost. We change the batery but all files are lost.Don't know what to do to get it up and running again because control CC300M is in somekind stop mode(READY 2 line on PS 100 is OFF). If anyone have the procedure for get it up please send me. If someone have backup of all files for this type of machine please send me. I have the PC communication software and cable for transfer the files to CC300M. Also have a lot of manuals and documentation for BOSCH CCxxx controlers if someone need.
    My e-mail: [email protected]
    May 2007
    2
    Bosch CC300
    Did U solve the problem yet?
    contact me : karmoleed at yahoo dot com
    Good Luck
    Jul 2012
    2
    ERROL 2670
    hello ........JIM FROM GREECE
    i have one CC 220 BOSCH
    first I had problems with error 277
    I change all the batteries (three batteries) and i made reload....377
    1- AUS EEPROM
    2 - inter password 377
    3- wait one Minute
    4- the soft key Rest will appear
    5-select RESET......
    AND RELOAD 281 FROM EPROM
    Now I have the error 2670
    -NC-FAULT 2670 - SPS TIME INHIBIT
    - PANEL FAULT- CLOCK POWER FAIL.
    AND THE READY 2 NOT LIT IN THE POWER SUPPLY...PS 100
    WE HAVE THE SAME ERROR...2670
    DO YOU HAVE SOLUTION TO ERROR ???
    f you have something to recommend me
    Jan 2012
    0
    error 277
    HELLO EVERYONE,
    I AM MOM FROM PAL
    I HAVE CC220 BOSCH AND THERE IS AN PROBLEM , CNC MACHINE NOT WORK
    Aug 2009
    4
    CC220 - fehler 277 - help
    When I turn on machine, 24V light green, but no noise of cooler and on screen I can see:
    EPROM TEST .... some numbers
    CHECKSUM-TEST ... ERROR
    MEMORY CLEAR
    MPP
    SYSTEM INIT
    P2INIT
    BACKUP LADEN AKTIV
    BACKUP LADEN ENDE
    on screen is:
    FRAN EPROM FRAN EEPROM OMLADDING SERVICE FUNCTION
    but nothing can be pressed.
    and it stop on FEHLER 277
    EDIT: now i continue to 2665 Spaenningsfall
    Nov 2014
    1
    Re: ERROL 2670
    Hi Guys
    We also are have a problem with our Trumpf 240 regarding the error 2670 - PC Time Inhibit.
    Please can anyone advise how to handle this one?
    Desperate!!
    Jul 2011
    4
    pass for BOSCH CNC CC220
    hi i need the [Click image for larger version.
ID:	265654pass] to copy a program 99990995 of manage EEprom
    thank
    Jul 2011
    4
    Re: unlock code for BOSCH CNC CC220
    Hello i have problems in cc300control no appears WAIT a press star bouttom , but in PLC the LED is ON
    Thank
    Jan 2016
    1
    Hello,I have problem with BOSCH CC300,PANEL STATUS..... NO DATA TRANSFER TO NC INTERFACE.... PANEL TRANSMITTER LINE FAULTY.
    Feb 2016
    8
    Hello,
    we have a problem with trumptc260R controller Bosch CC220
    we need to reload program fro EEPROM, and it keeps asking me for password.
    we tried 377,303 bu not working. any ideas?
    Regards
    Re: ERROL 2670
    Hi Belios,
    I know time has passed.
    Were you able to correct Error 2670?
    How did you do it?
    Sep 2009
    1
    Try to load from EPROM with password 281
    Jul 2015
    20
    Re: CC220 - fehler 277 - help
    can someone help me with the error on power on (12 NULLP, ACHSEN/MAGAZZIN) on cnc gloria, with BOSCH c200 controller, from a vertical center
    and guide me how to do tool magazin in home position
Page 1 of 2 12
  1. bosch cc220, need help
    By geo.less in forum Polls
    Last Post: 06-23-2016, 11:56 AM
  2. Problem on CNC Bosch CC220
    By mmcampelo in forum European Club House
    Last Post: 10-06-2011, 01:07 PM
  3. Bosch CC220 I/O problems.
    By tkran in forum Uncategorised MetalWorking Machines
    Last Post: 02-06-2011, 11:17 AM
  4. Problem with BOSCH CC220!
    By laserino in forum MetalWork Discussion
    Last Post: 02-06-2011, 11:04 AM
