586,634 active members*
2,902 visitors online*
    Mar 2008
    60
    Spindle Drive Fault
    I have an Interact l MK II with the KTK drive (Heidenhain TNC2500 Control). When starting the spindle I am getting a "Spindle Dirve Fault" alarm. I can reset and wait and sometimes get it going and it will run for a couple of hours (I work in the evening). When I first installed the machine I could start at lower RPM, but not start at much above 1000. I am running on a 20hp phase converter and I ended up installing some run capacitors and haven't had a problem for over a year. I have 240v. Is there some voltage checks/adjustments on the drive or the interface board I could check? On initial machine start up in my shop one of the capacitors burned up on the MT1-1 board. That was repaired and I have run for over a year. I have no manuals except from Heidenhain.
    Thanks for any help.
    Sep 2010
    84
    I have a similar issue with my BP Discovery 308 and the consensus was the power supply for the drives needed new caps as 17 year old caps are beyond there life cycle. I can ramp mine up to 6000 using 200 rpm steps but can't start it over 1800 without getting a drive fault. When I get time I'll replace my caps...
    John
    Mar 2008
    60
    What you are saying makes sense. Someone had posted some time ago some service sheets on the KTK drive and the MT1-1 board. I found on the MT1-1 board some adjustments. First was the amp adujustment, I have three different amp meters and I never could get a reading. The second adjsutment was the voltage at 4000 rpm, it was supposed to be 400v acorss the two leads, it was 280, when I truned that up, the spindle started real nice. Where are the caps, on the KTK drive?
    Sep 2010
    84
    I have a Siemens drive and have not looked inside of it yet. I was told by an ex Siemens guy that drive repair shops replace the caps first on old drives and then see if there is anything else wrong...
    John
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. spindle drive fault Arrow 500
    By scudzuki in forum Cincinnati CNC
    Last Post: 11-12-2010, 02:36 PM
  3. Replies: 4
    Last Post: 10-15-2010, 07:10 PM
  4. Spindle drive fault
    By Peat in forum Cincinnati CNC
    Last Post: 11-08-2008, 08:02 AM
  5. Spindle Drive Fault
    By n5jjr in forum DNC Problems and Solutions
    Last Post: 03-31-2005, 03:26 PM
