587,087 active members*
2,904 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > spindle drive fault Arrow 500
Results 1 to 16 of 16
    Aug 2008
    386
    1994 Arrow 500
    CT control, drives, motors.
    Fired up the machine today, powered on the servos, pushed the alignment button...
    halted with a spindle drive fault.
    Drive display shows -OC- (overcurrent?)
    Voltage looks okay everywhere.
    Checked the wires, nothing appears loose.
    Reseated all of the connectors.
    Tried a couple more times.
    Always got a spindle drive fault, sometimes the drive displayed -OC-, sometimes -UU-, sometimed rdy (ready, no fault).
    Anybody know of any problem areas to check before I send the drive out for service?
    Joe
    Sep 2008
    66
    drive fault
    good day Joe
    is it possible to hook a laptop to the drive to show the internal error?
    our arrow has A2100 control with kollmorgen drives and uses "Motion Link" as the software to setup and/or display internal drive problems.
    i'm not familiar with your control but, maybe CT uses something similar or even the same thing
    just a thought
    good luck
    Mac :cheers:
    Aug 2008
    386
    I've never seen any discussion of software for managining/diagnosing the spindle drive but that doesn't mean it doesn't exist.
    Joe
    Feb 2009
    6028
    Usually during power up it's a bad drive. You can try to disconnect the motor leads and see if the alarm changes.
    Aug 2008
    386
    Meaning if I disconnect the motor leads and it still alarms out it is the drive since I've ruled out a short in the motor?
    Joe
    Sep 2010
    1765
    if u disconnect the motor leads from a drive and it still faults out with overcurrent it is likely the drive is broke.
    Aug 2008
    386
    It doesn't overcurrent with the motor disconnected. The load meter ramps up as soon as I start aligning the axes. If I spin the spindle by hand when it tries to align the spindle, I can get it aligned. If I MDI an M3S500, the load meter goes to 157% (full scale) then faults with S: axis follower error after a few seconds since the commanded speed is not achieved.
    Joe
    Sep 2010
    1765
    The motor is disconnected and you still get an over current on align, or is the motor hooked back up?
    You can call Chris P at the office 937-660-5313 and I bet you two can get to the bottom of this pretty quick if you want!
    Aug 2008
    386
    No overcurrent on align with motor disconnected.
    The load meter maxes out when the axes are aligning (I guess the machine attempts to lock the spindle) then when it orients the spindle, unless I spin it by hand, it faults with orient time exceeded (wording not exact). If I spin it when it is trying to orient it will complete the alignment regardless of where I stop the spindle (oriented or not) just as long as the resolver is providing feedback that it is rotating. Once the machine is aligned if I command spindle rotation (motor is still disconnected) it errors with s: axis follower error (obviously since it's not spinning).
    I'll try to call Chris on Thursday. Going to the racetrack tomorrow woo hoo.
    Joe
    Sep 2010
    0
    Good morning Joe,
    This is Chris P, I dropped in on the thread this morning to take a look.
    If you do "not" get any over current alarms with the motor leads disconnected and you do get them with them connected then it sounds like your problem is in the motor/motor wiring.
    Maybe I'm not getting a clear picture here, if so feel free to call the shop and we'll catch up.
    Chris P
    Aug 2008
    386
    Thanks for the suggestions you provided on the phone today Chris.
    I checked the motor leads for continuity to ground and all 3 are wide open. Does not appear to be a short as it stands.
    A variable that I have thrown in is the z axis is down at its lower limit (left there in case I have to take the guard off to get to the motor) and it's possible that if there is a short in the wiring, it happens when the axis is closer to z max (which is where it end up when it aligns, of course). Can't test this theory since the drive is being looked at by a friend who's an electronics tech.
    Joe
    Sep 2010
    0
    Morning Joe,
    Wish I was able to be more help but as we talked about Kollmorgen and its Vickers/CMI AS10/VFS5 restamps are my forte. Hopefully your friend doesnt come up with anything and it turns out to be as simple as a shorted power cable.
    Regards,
    Chris P
    Aug 2008
    386
    Given my latest findings my friend is going to look at the drive first then come over with a megger to check the motor.
    Doesn't impact my near term future plans being as I have very little strength in both hands following a little "off-track excursion" at New Jersey Motorsports Park on Wednesday.
    Oh and take it from me, watch those mid corner throttle corrections.
    [nomedia="http://www.youtube.com/watch?v=IwFQrGc4Omc"]YouTube - This is why I suck[/nomedia]
    Joe
    Aug 2008
    386
    Up and running!
    After doing my best to rule out other components I sent the drive in to CT for repair.
    A shade under $2k later, I am making chips again.
    Joe
    Sep 2010
    0
    Glad to hear your up and making chips again! Wish I'd been able to give you more help with your CT spindle drive but unfortunately we specialize in Kollmorgen/Vickers.
    Hope your feeling better about your off road trip through the turn. Maybe some super motard tires?
    Aug 2008
    386
    I think you were plenty helpful given the circumstances Chris.
    Every few years I'll have an off track excursion like that and swear I'll never skimp on tires again. I've got the fear in me again, no more "just one more day on this front"... at least for a few years until I forget the pain...
    Joe
  1. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  2. Arrow 500 Drive Fault Error
    By macmub in forum Cincinnati CNC
    Last Post: 06-02-2009, 06:46 AM
  3. Spindle drive fault
    By Peat in forum Cincinnati CNC
    Last Post: 11-08-2008, 08:02 AM
  4. Cincinnati Arrow 500 Spindle Drive wiring
    By professor in forum CNC Machining Centers
    Last Post: 11-24-2007, 02:47 AM
  5. Spindle Drive Fault
    By n5jjr in forum DNC Problems and Solutions
    Last Post: 03-31-2005, 03:26 PM
