587,006 active members*
2,955 visitors online*
Page 74 of 76 24647273747576
Results 1,461 to 1,480 of 1506
  1. #1461
    Apr 2019
    145
    Re: Mach3 2010 Screen set
    Quote Originally Posted by basilio View Post
    I cannot see page 73 of this tread.
    The screen is all blue.
    The thread is finally fixed now. Sorry for waiting. One of your recent posts contained non-working HTML tags which destroyed the display. Therefore I had to delete it.
  2. #1462
    Nov 2017
    10
    Good afternoon.
    After uninstalling everything and reinstalling, I tried the Chinese Motion Controller macros and ... WORKS !!!
    Therefore, "Mach3Version3.043.062", the latest version of the "NcUsbPod.dll" plugin and Chinese Motion Controller macros, works perfectly.
    Thank you very much
  3. #1463
    Feb 2005
    829
    I have the below wireless MPG, it works under regular screenset but not the 2010 screenset.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Any tips to get it work Gerry?
  4. #1464
    Feb 2005
    829
    Ignore my post above, the wireless MPG started working.
    Wanted to ask, how hard would it be to integrate your tool zeroing functions into a different screenset that is more touchscreen friendly?
    Like this one?
  5. #1465
    35538
    All you really need to do is hard code the values into the macros that they normally get from the DRO's. And add some buttons. Although you could call the auto zero macros from MDI instead of buttons.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  6. #1466
    May 2019
    8
    Some feedback after using this screen set for a while.
    -I like it a lot!
    -When using the edge probing wizard I get a Divide by Zero error instead of an offset, usually when I am very close to perfectly straight. I suspect when the two ends read the same offset than it is 'perfect', in which case an exception in the code would handle it and say 'Perfect' or 'No Offset'.
    -While trying for the zillionth time to square my vise with the mill I remembered that there is a command to rotate the coordinate system, G68, which now makes sense. When I use it the main coordinates turn red and zeroing an axis won't actually make it zero. I suspect I need to carefully study how this command affects the other commands. However, it is incompatible with the XY probing wizard and I get an error as soon as I click the XY probing icon then the window immediately closes.
    The first item seems really easy to fix, the latter could be a real headache!
  7. #1467
    Good afternoon.
    Thank you very much
    hi can you post the link for the last drivers?? thanks
  8. #1468
    35538
    I could probably fix this, but I recent;y moved, and don't have a functioning machine to do any testing at the current time.
    You need to zero both the X and Y axis. Doing a quick test in Demo mode, it looks like the coordinates are displayed in the non rotated coordinate system? And jogging is not rotated?
    Say I rotate the coordinate system 45°, and jog to the right (X+), both coordinates change. Zeroing Y doesn't do anything, because Y hasn't changed. But if you zero X, they both go to zero.
    Seems like it's one of the many issue in Mach3, where a feature is only partially implemented?
    Any chance you can get a screenshot of the error? I'm only in demo mode here, but I can start the probing wizard here while in G68 mode, and even run the macros with no issues. Might be an issue with your Mach3 installation.
    Gerry
  9. #1469
    Nov 2017
    10
    Quote Originally Posted by jdavidbarrera View Post
    Try these
  10. #1470
    Nov 2017
    10
    Good Morning ger21.
    How to use a 3D digitizing Probe at Mach3 2010, to auto level?
    I plan to carve on a convex surface, and need to carve the text with an equal depth across the surface.
    I used the G Code Ripper, but since I bought the 2010 screenset, I would like to know if it can do that or if I have to continue with the G Code Ripper
    Thank you.
  11. #1471
    Jun 2020
    1
    Question Re: Mach3 2010 Screen set
    Just bought 2010 Screenset, using with Mach3 V3.043.066 TC-50M and have used Chinese motion control macros as std ones did not work. But still have issues.
    On X+ probing script for example the Probes moves correctly for the first touch, stops on contact then moves to -ProbeD/4, it then moves again to the -Clearance position, while moving the DRO resets to -6 (Clearnace +D/2 which should be final position) the probe then moves to make the 2nd touch at feedrate 2. on touch the probe stays in contact and reports Probe in complete, but the tool is not correctly zeroed.
    If I step though the macro in the editor it functions correctly. But if run nIormally it appears to ignore the While IsMoving() and Wend on the 2nd probing and runs to the end before the probing is complete.
    I have tried putting in some sleeps to wait for the probing to complete but just freezes the macro and have to reset Mach3 to unfreeze.
    Any ideas?
    Phil2112
  12. #1472
    Sep 2011
    1183
    Hi my XP Pc crashed I had a new HD installed Mach3 works good, but glitchy with the 2010 screen set I noticed a lot of the settings were not checked I have tried to get it to configure right it but no luck. I was wondering what is the best way to fix uninstall or?
    http://www.cnczone.com/forums/diy-cnc-router-table-machines/140832-cnc-software.html
  13. #1473
    Sep 2011
    1183
    I corrected the problem all is well now.
  14. #1474
    35538
    Sorry, I missed your post yesterday.
    Gerry
  15. #1475
    Sep 2011
    1183
    No problem all is well thanks, Gerry.
  16. #1476
    Sep 2013
    23
    Ger, Does you 2010 screen set work on Win XP? Yep still runnin the 1024 set and XP. I have a leadshine 3660controller.
    Jim
  17. #1477
    35538
    It works with any OS, and was created on an XP machine 10 years ago.
    Gerry
  18. #1478
    Sep 2013
    23
    Thanks for the quick response, I downloaded Big Tex's tool setter 3.4 and have it mostly working but after every zero routine my Z crashes to the top limit switch. I have to stop it before the limit. When moving to Park Coordinates it Z raises to limit and crashes, after Zero initial, and when it moves to my fixed plate zero's then raises to z limit. Can't seem to make the Laser off set do anything. I saw something in the thread about a capacitor? In my old autozero routine I designated a safe Z.
  19. #1479
    Apr 2005
    304
    Quote Originally Posted by JimBar View Post
    Check your SafeZ settings. BigTex 3.4 should work flawlessly.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  20. #1480
    Sep 2013
    23
    No Joy, tried safe Z for all co-ordinates. When back to my 1024 to get a job done, seems like it works fine with M6start from Big tex, i overwrote it by mistake, thought I copied and pasted but not in the folder? Anyway I am now getting the laser zero to work but in the wrong direction if I try to put in negative coordinates it just changes them to positive? Rabbit hole here I come.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. Econo-Probe Setup with Mach3 + Ger's 2010 Screenset
    By jmc2010 in forum CNC Machine Related Electronics
    Last Post: 06-24-2014, 04:21 AM
  3. G100 + Mach3 2010 screen auto tool zero
    By Menatep in forum G-REX
    Last Post: 05-02-2014, 10:13 PM
  4. Strange Issue with 2010-4 Screen Set in second machine profile
    By JoeKumanchik in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2014, 11:27 PM
  5. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
